Rollover_Red Posted May 8, 2015 Report Share Posted May 8, 2015 So when I built my lz22, I think I may have put my dipstick tube a little too far down. How do I properly measure how far it goes in to show the correct amount of oil? Quote Link to comment
Rollover_Red Posted May 8, 2015 Author Report Share Posted May 8, 2015 Also, it's a z22e block, l16 oil pan/sump/dipstick. Quote Link to comment
shacks510 Posted May 8, 2015 Report Share Posted May 8, 2015 Do you have a straight L series tube? On my L20 block, the bottom of the tube is about 1/16" from the bottom of the hole inside the block. Quote Link to comment
shacks510 Posted May 8, 2015 Report Share Posted May 8, 2015 Also, it's a z22e block, l16 oil pan/sump/dipstick. Oh ok. You beat me to it. 1/16" from the bottom of the dipstick hole as I said. Quote Link to comment
Rollover_Red Posted May 8, 2015 Author Report Share Posted May 8, 2015 Ok, I'll redo it when I put my new oil sump on. Quote Link to comment
shacks510 Posted May 8, 2015 Report Share Posted May 8, 2015 Might as well repaint the bay while the engine is out. "Weekend Job" :D Quote Link to comment
datzenmike Posted May 8, 2015 Report Share Posted May 8, 2015 So when I built my lz22, I think I may have put my dipstick tube a little too far down. How do I properly measure how far it goes in to show the correct amount of oil? Fill the engine with the exact correct amount of oil. Mark where the oil level is on the stick and that's the correct amount. Quote Link to comment
Farmer Joe Posted May 8, 2015 Report Share Posted May 8, 2015 is the dipstick in the stock hole on the passenger side, or did you leave it on the driver side? if its the stock dipstick tube, stick, oil pan, then it would be like normal. if its the Z block tube and stick, then itll have to be drained, filled with 4 qts and then marked like mike said.. Quote Link to comment
