Stankalonius Posted May 6, 2015 Report Share Posted May 6, 2015 when I get up to he's tired than 65 miles an hour I notice that there is a rattle that comes from the shift lever. If I put my hand on it, this goes away, but I can't feel deliver vibrating. is there something that I can type in to stop this? Am I in any danger of getting thrown out of gear or anything of that sort? Thanks! Quote Link to comment
Ratwagon1600 Posted May 6, 2015 Report Share Posted May 6, 2015 Gearbox i.e. dogleg 5 spd? Dependent on the type of gearbox, some will have plastic bushes where the clevis pin retains the shift lever. These can wear/break. Other times the bush on the ball at the base of the gearstick can wear/break. Bloody near impossible to diagnose this one via the keyboard. This is Ratsun, pics of said gearlever with the shift boot removed are a must in the first instance ! Quote Link to comment
Stankalonius Posted May 6, 2015 Author Report Share Posted May 6, 2015 79 210, 4speed A14. I will post some pics when I get home.I'm glad you understood what I meant, I was using voice recognition on the freeway when I made my last post and it looked funkier than I thought it would. thanks for the prompt reply. Quote Link to comment
Ratwagon1600 Posted May 6, 2015 Report Share Posted May 6, 2015 Voice recognition, ye gods ! For a second I thought it was Jrock or Hainz posting in their modified English. Im not familiar with the standard A14 four speed. Having said this, a trick you can do to take some of the slop out of the L series shift levers is to put a spring washer between the shift lever and the tabs on the gearbox housing (on the inner side). Ill try and post a pic later which will make more sense. 2 Quote Link to comment
datzenmike Posted May 7, 2015 Report Share Posted May 7, 2015 Both the A12 4 speed and the A14/15 4 speed use the same bushings.... Control lever bushings.... 32855-H1010 under $5 for both Control lever head.......... 32861-H7301 under $2 each (one needed) Quote Link to comment
Stankalonius Posted May 8, 2015 Author Report Share Posted May 8, 2015 it's probably worth just picking up both of those things and installing them? Quote Link to comment
datzenmike Posted May 9, 2015 Report Share Posted May 9, 2015 Won't hurt your wallet. Quote Link to comment
jesusno2 Posted May 9, 2015 Report Share Posted May 9, 2015 Yup had the same issue in my B310, the 510 shifter bushings are the same thats what i used got em from chico nissan on ebay Quote Link to comment
