610StaWag Posted May 3, 2015 Report Share Posted May 3, 2015 I didn't do right storing our 610 for 16 years. Two cylinders are WAY down on compression. I am not in the position to take apart the engine and do a rebuild. I have done that in the past, but now I don't have the tools and I am not up for that kind of project. Does anyone have a stock Datson engine that could go into the 610? I have seen many folks put hod rod (dual cam, etc.) engines in their cars and I wondered if anyone has an old stock engine (that runs) that they don't need and are willing to sell it. ps, Is it practical to think of putting in an automatic trans in place of the original sloppy shifting stick? Thanks, Donald Quote Link to comment
datzenmike Posted May 3, 2015 Report Share Posted May 3, 2015 Any L 4 cylinder will fit. You may need to put your oil pan or exhaust manifold on it. Easier to switch to an auto from a stick than the other way round. Quote Link to comment
DanielC Posted May 3, 2015 Report Share Posted May 3, 2015 This is a long shot. Try putting some ATF in the spark plug holes. Turn it over with the plugs out, put more in. Let it sit for a while, over night, a few days, or a week Check compression again. If you can get it to fire and run, run it, check compression again. Engines that sit for a long time sometimes have the piston rings get stuck in the pistons. The ATF helps loosen them. Adjusting the valves might get the compression back, also. Quote Link to comment
datzenmike Posted May 3, 2015 Report Share Posted May 3, 2015 Several valves may have been off their seats and are .... 'rusty' and not sealing that well. As Daniel said... run it for a while to break it in. Quote Link to comment
banzai510(hainz) Posted May 3, 2015 Report Share Posted May 3, 2015 L16 L18 is the same height. run the motherfucker ansd readjust the valves olddatsuns.com Quote Link to comment
banzai510(hainz) Posted May 3, 2015 Report Share Posted May 3, 2015 ps, Is it practical to think of putting in an automatic trans in place of the original sloppy shifting stick? why??????????????if works already Quote Link to comment
