maredlin1@hotmail.com Posted April 29, 2015 Report Share Posted April 29, 2015 Do you think it might be beneficial to mix a little oil with the gasoline in a fresh rebuild ? Quote Link to comment
banzai510(hainz) Posted April 29, 2015 Report Share Posted April 29, 2015 NO!!!!!!!!! just prime the oil pump.!!!!!!!!!!!!!!!!!!!!!!! prime carb so gas is squirting in carb. I pour oil on cam lobes and down chain before startup. 1 Quote Link to comment
Andres131313 Posted April 29, 2015 Report Share Posted April 29, 2015 Just prime the pump. It may take 10 sec if you didn't fill the pump before installing it. The Assembly lubricant should prevent a completely dry start also. Quote Link to comment
datzenmike Posted April 30, 2015 Report Share Posted April 30, 2015 Never. The oil won't burn as the gas and air are mixed in the proper ratio and there is no oxygen left over for it. The heat will coke or carbonize the oil and leave a thick deposit on the piston, rings, plugs and valves. Carbon is very abrasive. If you have rebuilt your engine properly the rings will get all the oil lubrication they need. Quote Link to comment
john510 Posted April 30, 2015 Report Share Posted April 30, 2015 Only if its a 2 stroke 3 Quote Link to comment
banzai510(hainz) Posted April 30, 2015 Report Share Posted April 30, 2015 It may take 10 sec if you didn't fill the pump before installing it????????what???? prime the pump!!!!!!!!!! Quote Link to comment
datzenmike Posted April 30, 2015 Report Share Posted April 30, 2015 At the least pull the coil wire off so it doesn't start and crank 3 or 4 times at 10 seconds each. Quote Link to comment
Lockleaf Posted May 2, 2015 Report Share Posted May 2, 2015 I poured racing 50wt over my whole valve train and all over the timing assembly before my first crank when I rebuilt my z24. Even priming the pump wont do much because you can't prime the whole system on these engines like you can a chevy or a Ford. Assembly lube is your best friend, followed by break in additives in your first few oil changes. I like how busta nut packs his timing assembly with assembly lube. Quote Link to comment
datzenmike Posted May 2, 2015 Report Share Posted May 2, 2015 You can fill the oil system by filling the pump, disconnecting the coil so it won't start and cranking the engine over for 10 seconds or so. Leave the valve cover off and you'll see the oil when it get's up there. Quote Link to comment
Stoffregen Motorsports Posted May 5, 2015 Report Share Posted May 5, 2015 The only time I ever prime an oil pump is when it's a race motor. Otherwise I just pack the pump with Redline assembly lube and drench the cam and valvetrain with oil then fire it up. If there is fuel in the carb and the timing is close, it should fire within seconds and build oil pressure quickly. Quote Link to comment
Ratwagon1600 Posted May 5, 2015 Report Share Posted May 5, 2015 The only time I ever prime an oil pump is when it's a race motor. Otherwise I just pack the pump with Redline assembly lube and drench the cam and valvetrain with oil then fire it up. If there is fuel in the carb and the timing is close, it should fire within seconds and build oil pressure quickly. This ^^^^^^^^^^^^ is the way RW has always done his motors. As John510 said, oil and petrol mixes are only for two strokes. Quote Link to comment
DaBlist Posted May 5, 2015 Report Share Posted May 5, 2015 These guys want you to believe you should But I never have Worked with a guy that used to pour this down the intake to help break in the rings But I never have 1 Quote Link to comment
DaBlist Posted May 5, 2015 Report Share Posted May 5, 2015 Just run a Fram filter to keep fines circulating and the rings won't glaze. Like Tanker does. 1 Quote Link to comment
datzenmike Posted May 7, 2015 Report Share Posted May 7, 2015 The old formula Bon Ami had volcanic pummace in it for scowering sinks. My rule is Nissan knew what they were doing when building engines. They didn't use it.... YOU should't use it. Cars/rings and oil have come a long long way since the '50s... hell car makers back then didn't use it. They often did use 'break-in' oil to speed the seating of the rings. Quote Link to comment
Stoffregen Motorsports Posted May 7, 2015 Report Share Posted May 7, 2015 You bring up a good point. If the oil is too slippery it may not help the rings seat properly. Another common misconception is how you're supposed to drive until it's all broken in. On the dyno, the engine gets revved up and down slowly for the first couple of minutes, followed by a couple medium pulls to the upper middle of the RPM range, then full power runs under redline. Full break in of rings should take mo longer than a few minutes. On the other hand, if you drive it too gently, the rings run the risk of never seating properly at all. Varying RPM's under medium load is key. Quote Link to comment
banzai510(hainz) Posted May 9, 2015 Report Share Posted May 9, 2015 prime the pump and leave rings dry is what my block builder says, Rings will seat FAST Quote Link to comment
