'62 Falcon Econoline
So I bought a pair of bitchin' "Rally Car" style roof vents thinking I'd put one behind the head of the driver's and passenger's seats.  I fingered sucking air out above and behind the head would draw it over the body and cool nicely.  Yeah, the only place to put ONE of them is right in the center between the seats... so I'll be doing that instead.  The other vent will probably go in the Baja 1200.
  • Replies 626
you call that rally style. I call that peterbilt bed vent
You say "tomato," I agree with you that it is pronounced "tomato."
I did, however, find them from a post on a Rally Car forum so I also say, "Go grease Wheezer!"
Decided to get cracking on the seats...   :thumbup:
Driver's side in (along with the doghouse) for a test fit...
19598514_1389232717822515_88840797557009
Had to drill one hole for the left front leg to get started and propped it up on some screw jacks...
19510584_1389232697822517_71009218191005
Seating position is a tiny bit high, but workable. Plans are afoot to rebend the shifter up a bit to stop it banging on our knees in third gear...   :thumbup:
After a lot of measuring it looks like the stock inner seat bracket can be modified to work on these seats as well...
19598495_1389232724489181_69951412669785
Once we get that firmly attached to the seat, we can bolt it back in and get to work fabbing a left rear mounting point. Hopeful for more progress tomorrow...
does this thing come with seatbelts?
We discussed that today.  At most, it would have had lap belts so that's probably how we're going to roll.  I suppose I could "engineer" some three-point belts, but since my feet are the crumple-zone, I figure: Meh, something's going to kill me some day.
Yeah, I saw those as well but making suitable hard points for the lap belts is going to tax my patience enough already.  I went with a similar kit with just the lap belts.
Windshield out...
19875186_1393505914061862_59595979608791
Set aside for cleaning...
19732136_1393505944061859_44681499502692
This window also had the goo inside the seal that had to be cleaned off...
19665390_1393505917395195_88878448531270
Glass cleaned, seal stretched on, and now installed...
19656910_1393505977395189_72351068174090
Previous owner had a hula girl or somesuch stuck on the dash, and the idiot who painted the dash didn't bother to clean the glue off the dash before painting it. So we had this ugly circle of no paint in the center of the dash. So...
19702241_1393506037395183_44853054229980
Because the shifter was banging your knee in third gear, we took it out and went to the press and bent it a little...
19657482_1393506147395172_32894892366674
First gear, tight but workable...
19702013_1393506127395174_86041567650897
Second gear...
19657045_1393506190728501_48172831015541
Third gear location is much improved...
19756441_1393506137395173_67644547845896
The Hello Kitty is double-sided...
19657108_1393506227395164_67584793293580
Also got the wiper linkage and wipers reinstalled...
19732291_1393506250728495_61121307264733
The aforementioned purple seat belts...
19895092_1397484793663974_32145411953073
Potential shift knob donated by our shop neighbor...
19894941_1397484790330641_54736279252988
Two things tackled today, radio install and fuel filler neck fabbed...
Got a double-DIN to single-DIN conversion kit for some Corolla...
19958898_1397484270330693_40230536768935
Made a template for the hole we needed and transferred it to the metal...
19756618_1397484260330694_15133369207892
Got to cutting...
19756859_1397484266997360_91375933262166
Like a glove...
19748594_1397484326997354_88872559246692
Took it out and installed some rivnuts in the top...
19732353_1397484333664020_15725764231162
Now bolted in with the radio...
19875120_1397484353664018_40690629284327
Tim made  blockoff for the stock speaker hole...
19748687_1397484373664016_58910795452624
Probably next week we are going to mask it off and paint it black inside the curved line where the radio/gauges are...
19732303_1397484440330676_28171262628141
Then we got cracking on making a fuel filler pipe. First to remove the filler cap from the fuel cell...
19756388_1397484516997335_84083420776629
Then replace with a filler neck piece...
19748783_1397484520330668_45761429106890
Decided it would be less painful to drill it from the inside...
19883970_1397484553663998_61051504909175
Although this was kinda cool to watch...
19756595_1397484636997323_85278571994417
And now the filler is in...
19748557_1397484653663988_27014863512606
Tim welding the tubes together...
19875223_1397484656997321_76721907899976
Test fit...
19875351_1397484726997314_22340863678922
Cut a piece of straight pipe to fill the gap, got it tacked into place for the final test fit...
19756593_1397484840330636_50587800284539
After that, we took it back out, Tim finished welding it, and I cleaned it up and painted it. Should be in for good next weekend.  :thumbup:
  • Like 3
After staring at that last picture for a while, I've come up with a few thoughts:
1) My left thumb bends funny and you can really see that wicked scar from slicing it to the bone as a kid.
2) I think the pipe needs a support going to the floor.
3) I think I want to install the second tank on the opposite side of the van and "Y" off of this filler to it.
4) I'm not sure where we want to install it, but we need to install a vent.
A good scrub and break out the tape...
19990034_1405019062910547_90707685754128
Took the steering wheel off so I could paint the column as well,after the first coat...
19990084_1405019089577211_68555060693129
And done...
20031736_1405019119577208_99423260981477
Still wet in that pic, should dull a bit when dry. Probably going to use some purple pinstripe as a break between the silver and black..
While I was doing that, Tim was playing with his pipes...   ^_^
20139735_1405019072910546_62029187381089
Four was deemed a bit to over the top, so went with two...
19961359_1405019169577203_61800467554262
Decided to sort of make a giant Ansa tip...   :P
20106752_1405019189577201_24962648066894
And done for now...
20139745_1405019226243864_47350563790217
  • Like 4
I flew a solo mission at the shop today and installed the new purple steering wheel with purple spacer thingy.  We're beginning to get a bit of a mish-mash of different purples going on, but I think it is going to work.  I was going to hang the zorst pipes/mufflers but realized a) it was hot as balls, and 2) that was going to be a 2-man job.  Then I was going to hang the zorst tips but realized a) it was still hot as balls, and 2) THAT was going to be a 2-man job as well.  So I had a look at the speaker situation again... which now I can't remember if we've even discussed that situation here.  Anyhoo, whether or not we have discussed it, I'm going back to the original plan of 6.5" round speakers just to the inside of the vent titty things.  I zooked a pair of "feet" to a round rod which wedges in between said titties nicely.  We'll attach the speaker boxes to that and maybe float the amp in between those items.  I'm hoping that the cross bar will disappear and make the speakers and amp look like they are floating.  We'll see.
  • Like 3
