'62 Falcon Econoline
  • Replies 626
The item I purchased, for which the Y-pipe was needed, arrived today.  And, as the actress said to the bishop, it is much bigger than I expected.  I'm going to ask a cohort if he would be willing to swing by Summit on his way home to look for a proper Y-pipe... because this thing is really cool.  No, I'm still not saying what it is until we can post pictures of it!  Patience, grasshopper!
I did pick up said y-pipe, which it now appears we will not be using, so...   :rofl:
Here's Tim's new exhaust tip, that may end up on his 1200...
26230633_1557612797651172_61854640069404
Tim came up with an interesting idea on how to make a dual side exit exhaust. Start with some bends and make this...
26047336_1557612804317838_10514473881385
Then we will weld two pipes into it, something like this...
26001003_1557612807651171_64514252483985
Attach those to the two mufflers, then you have a nice big sort of resonator chamber for the exhaust that will exit on either side just in front of each rear tire. It's wacky, but we think it'll work just fine.
Current plan is to insert said pipes like this, hoping it will keep both pipes somewhat divided...   ^_^
26169355_1557612880984497_43259581658877
The big pipe is made from 3" tubing and we have some 20" long chrome 3" tips for it. Small pipe is 2" tubing which mates up well with the current mufflers.
And in case it isn't obvious, the dip in the center is so it can go over the driveshaft, because that shit was right in the way...
I went to the butt-ass butt-butt cold shop today to have a look at this again.  I took a measurement from the driveshaft to the muffler then transferred that to the big pipe.  Yeah, Houston... we have a problem.  Y'all see that weld where the hump in the 3" pipe begins?  That is where the muffler stub wants to intercept the big pipe.  Before I did anything permanent, I called it a day.  John and I will grok it again this Saturday.
Well, we spent a lot of time working on getting the driver's seat mount figured out, then ran into a problem.
See, the seats I bought were a fairly tight squeeze between the doghouse and wall. Then today we noticed that the doghouse is offset to the passenger side by two inches. So now there's not a chance in hell the passenger seat will actually fit in the van...
So it is back to the drawing board on that. Tim has some fun ideas on that front...
Also after grokking the exhaust situation, it's looks like we are going to back up and punt and do a dual exit on the passenger side instead, so...
Grok?
No entiendo.
Yeah, we're not technically using the word correctly.  We mean "to study or examine something in order to understand it."  Robert Heinlein meant for it to mean "to understand something intuitively."  But I often use words I don't fully understand when I want to sound photosynthesis.
https://en.wikipedia.org/wiki/Grok
  • Like 4
I hate to be pedantic, but this is at least plan D for the zorst... ok, ok, I LOVE to be pedantic!
Also, you forgot to show/tell them the best part about the passenger seat...
It spins round backward!
Captains chair for the passenger? :lol:
Perhaps passenger doesn't want to see the driver's driving?
Actually, it is more to create a conversation pit sort of thing... and/or not have two MoG sitting on the sofa to watch the TV.  Hmm, I might have to make a dining table of some sort now.
Did some more exhausting today...
Took the two elbows and welded extensions on them...
26994174_1578614945550957_20367725645701
Also welded on a bracket to mount a hanger to, as well as took a 3" exhaust tip and squeezed it down on the end to slip over the pipes just to see how it looked/worked...
26733983_1578614948884290_28079607375988
This was deemed too "mad bosozoku" for this project so we did something different...
26734495_1578614952217623_24050849652049
And a test fit on the van...
26992530_1578614972217621_53772426209916
That was deemed acceptable so we took that off to seam weld the tips on...
26804383_1578615155550936_67958191321671
I really like this picture for some reason...   ^_^
26805101_1578615118884273_68267274379956
Had a little difficulty welding the tips on because they really need a MIG not a TIG, so Tim will have a muffler shop finish the job at some point in the week. Should be permanently installed next week.   :thumbup:
Four hours a week, three weeks a month, just isn't enough time for these projects.  I'm planning to go to the shop tomorrow after lunch to install the driver's seat.  I might take another stab at zooking up the huge gaps twixt the tips and pipes with the TIG.  Worst case*, I'll do as D-freak said and have an muffler shop fill it in with a MIG.  Well, truly worst case* is I go buy myself a MIG so I can fill the gaps... we'll see.
* By "worst case" I mean most expensive, of course.
Exhaust in and (hopefully) finished...
27751609_1592760724136379_77881999685648
27540353_1592760704136381_13249068236919
Tim found some cool purple door knobs, too. We are thinking one for the steering wheel spinner, one for the shift knob, and maybe one for the e-brake handle...
27331871_1592760917469693_13752794859243
Also finished welding up the passenger side seat mount...
27336722_1592760937469691_36027710265015
After that, i scrubbed it up and painted it as well. Should be going back in next week but we can't do the final install until we put carpet in the front half of the van...   :thumbup:
Tee hee!  Purple knobs!
Ok, now that my inner 8yo has had his say, I want to add "Driver's seat adjuster handle" to that list of recipients
I'm not sure if we ever 'splained why we moved the zorst from center exit at the rear to this side shooter arrangement.  Trailer hitch.  We're going to install a trailer hitch after all.  Ok, that seemed like it was going to be a longer/more interesting story when I started typing.  Meh, deal with it.
And I see that my "Post Whoring" has, once again, pushed us to a new page.  *Sorry about that.
*And by "Sorry about that." I mean "I'm totally not sorry at all!"
  • 2 weeks later...
Finishing the welding on the driver's seat frame...
27867956_1600834209995697_67385329272435
Both seats in for a test sit...
27752435_1600834206662364_55055537237481
Driver's seat has a slider, passenger does this...
27752059_1600834203329031_66567324821324
And so we did...
27655272_1600834273329024_17140010227480
Also spent some time looking at locations for the rear speaker boxes and still not sure we've decided...
