sebpv Posted April 26, 2015 Report Share Posted April 26, 2015 Hi, just disassembled the rear brake and I wanted an opinion on the overall look of my hub assembly. I dont know whats good, normal or bad. So heres a picture: Sorry I dont think its necessary to show the internals. The bearings beads each rolls freely. Its covered in "clean" uniform black oil. The axle seal is good, intact and soft. There was a thin film of grease/dirt/dust coated on the drum internals. But I dont know how to translate that grease you can see between the axle and the backing plate... Help? Quote Link to comment
ggzilla Posted April 26, 2015 Report Share Posted April 26, 2015 It looks normal. Oil is bad. What I would do is pull the axle shaft, pack it with axle bearing grease, and fit a new seal. Quote Link to comment
datzenmike Posted April 26, 2015 Report Share Posted April 26, 2015 Looks clean and dry, leave alone. Quote Link to comment
Doctor510 Posted April 26, 2015 Report Share Posted April 26, 2015 Check for a bad wheel cylinder too... Quote Link to comment
sebpv Posted April 26, 2015 Author Report Share Posted April 26, 2015 Just had 2 bolts to remove, so I figured what the hell, just do it. Im not good with words so: Keep in mind I pressured washed where accessible. Behind the hub I couldnt, hence the gunk u saw...Also by the look of the "clean ring" u can see the axle seal does its intended job. The wheel cylinder is being looked at. It still have the rubber cups and all. But the lower thingy had what looked like "dried coolant" before I washed it. Quote Link to comment
ggzilla Posted April 26, 2015 Report Share Posted April 26, 2015 Yes, you can see how the bearing grease is gone. Good that you caught it in time. Quote Link to comment
sebpv Posted April 26, 2015 Author Report Share Posted April 26, 2015 for your entertainment: some shmuck... Yup, she's wet... Quote Link to comment
sebpv Posted April 26, 2015 Author Report Share Posted April 26, 2015 Ok so you say I need a new bearing? Based on the fact that the bearing is covered in oil? So lemme guess: grease normally in the hub compartment and oil beyond the seal? Quote Link to comment
ggzilla Posted April 26, 2015 Report Share Posted April 26, 2015 Yes grease normally in the bearing and oil beyond the seal. No one said anything about needing a new bearing. Quote Link to comment
sebpv Posted April 26, 2015 Author Report Share Posted April 26, 2015 Ya sorry. But now I take I need at the very least a new axle seal? Quote Link to comment
ggzilla Posted April 26, 2015 Report Share Posted April 26, 2015 Well its not required. Back in the day when I had no money I would pack the bearing every couple months when the leaking oil washed out the grease and started showing. However if you replace the seal it ought a be good for years. Quote Link to comment
sebpv Posted April 26, 2015 Author Report Share Posted April 26, 2015 Thanks everyone for your help and quick replies. I LOVE RATSUN.NET! To confirm your sayings I pulled the pass brake assembly. Yup grease in the hub assembly... Quote Link to comment
sebpv Posted April 27, 2015 Author Report Share Posted April 27, 2015 Now can someone expend on the hammer and piece of wood technique to remove the bearing? First I straighten the "gear" tooth I guess, but then? I also read something about hammering the front hub counter-clockwise but why and how? Quote Link to comment
ggzilla Posted April 27, 2015 Report Share Posted April 27, 2015 Don't remove the bearing. Just pack it with grease. Work it in with your fingers. Btw good use of photos. Quote Link to comment
sebpv Posted April 27, 2015 Author Report Share Posted April 27, 2015 Should I be worried that the outer bearing could be dry as well? Will the grease make it all the way to the front face of the hub? And should i hit the hub assembly with brake cleaner first in order to get as much oil out as possible? Quote Link to comment
ggzilla Posted April 27, 2015 Report Share Posted April 27, 2015 You want to grease the bearing, not the hub. Do you have a repair manual? Quote Link to comment
sebpv Posted April 27, 2015 Author Report Share Posted April 27, 2015 Ive got the Haines manual if thats what you mean. To be honest, I didnt think about reading that section Quote Link to comment
