Mathias_meza Posted April 21, 2015 Report Share Posted April 21, 2015 Hello I'm new to ratsun i am having trouble lowering the front of my trucks do in need to rein dex it ? If yes how would I do that Quote Link to comment
flatcat19 Posted April 21, 2015 Report Share Posted April 21, 2015 There is a video pinned in the 521 section. Read the pinned topic in general discussion aptly titled "Read This First." Quote Link to comment
datzenmike Posted April 22, 2015 Report Share Posted April 22, 2015 Also try typing 'lowering the 620' or 're-indexing torsion bars' into the search function and start going through the tons of information on this well covered topic. Quote Link to comment
Jester Posted April 22, 2015 Report Share Posted April 22, 2015 Re index your torsion bars. Here you go. Quote Link to comment
ggzilla Posted April 22, 2015 Report Share Posted April 22, 2015 Ratsun Search is useless - 're-indexing torsion bars' finds this topic but none of the others Google search works however Quote Link to comment
kelowg Posted April 22, 2015 Report Share Posted April 22, 2015 Google it but put " /ratsun" at the end. Just loosen torsion bolts at back end of bars. Reindex if going more than couple inches. Also cut down or remove bump stops. Quote Link to comment
datzenmike Posted April 23, 2015 Report Share Posted April 23, 2015 Ratsun Search is useless - 're-indexing torsion bars' finds this topic but none of the others Google search works however Funny I get... http://community.ratsun.net/topic/24073-torion-bar-reindexing/ http://community.ratsun.net/topic/6554-reindexing-and-shocks-questions/?p=83024&hl=reindex&fromsearch=1&do=findComment&comment=83024 http://community.ratsun.net/topic/44675-help-wanted-how-to-lower-front-of-86-720/ ...and more. Quote Link to comment
Hawaiian620 Posted January 4, 2016 Report Share Posted January 4, 2016 Old thread, but I didn't want to start a new one. I'm able to remove all but the last third of both bolts. I notice two nuts up top, is there a certain way to remove them? I tried tons of pb blaster, bolts and nuts are in good condition and came down easily, then stopped at the same spot on both sides. I want to reindex, but this is preventing me from doing so. Thanks in advance! Quote Link to comment
flatcat19 Posted January 4, 2016 Report Share Posted January 4, 2016 Turn the bolts away from each other to remove one at a time. They're jammed together as a lock. Maybe wire wheel the remaining threads to prevent all the threads from getting buggered. Quote Link to comment
Hawaiian620 Posted January 4, 2016 Report Share Posted January 4, 2016 That's what I was thinking. I'll try that tomorrow. Thanks for the quick response! I'll post up if it doesn't work. Quote Link to comment
