85 nissan 720 with Z24
Minesmith67
Wasn't firing carb is rusted shut as far as plugs I already pulled and they were nasty. Motor has about 2.5 gallons of water in it so I draied the motor and pulled all plugs and turned the motor over a bunch to clear it out
  • Replies 64
Ha ha ha it's 2.4 liters half of which the pistons are at TDC so 2.4 / 2 = 1.2 liters.... I'd call that a fat US quart. :lol:
I pulled the plug on oil pan and what came out of the motor almost filled a 5 gallon bucket. It was in seattle Washington where it rains a lot. It has been tarped the entire time but tarps can leak. And Charlie69 I was hoping to fire it but as you can see I didn't. And Rhino13 it's been sitting for about 6 years but the motor is still very clean I took the valve cover off No rust. I took off oil pan also no rust. I plan of running some oil cleaner stuff in bit to clean it out then put a good oil in the motor. Or if someone has better ideas let me know.
If the block was filled with water there will be a rusty 'bath tub ring' on the inside. Seen this before. As long as the cylinders were dry you have a chance. Oil would have protected the crank bearings from rust.
