COOCHaDAMus Posted April 18, 2015 Report Share Posted April 18, 2015 i gotta 80' 210 my research has come up empty. the metal brake hose that connects between the caliper to strut. is there any rubber or braided line to replaced that crappy metal brake line. Quote Link to comment
flatcat19 Posted April 18, 2015 Report Share Posted April 18, 2015 From the caliper to the strut should be rubber. http://www.ebay.com/sch/i.html?_from=R40&_trksid=p2050601.m570.l1313.TR0.TRC0.H0.X1980+datsun+210+brake+hose.TRS0&_nkw=1980+datsun+210+brake+hose&_sacat=0 There is a member here named hosestop@msn.com who makes stainless hoses for all things Datsun. Quote Link to comment
ggzilla Posted April 18, 2015 Report Share Posted April 18, 2015 Why does it annoy you? It is stiffer than any hose, even a stainless braided hose. Dont fix what ain't broken. Quote Link to comment
COOCHaDAMus Posted April 18, 2015 Author Report Share Posted April 18, 2015 Why does it annoy you? It is stiffer than any hose, even a stainless braided hose. Dont fix what ain't broken. bought some rotors and i really don't want to have to bleed the brakes to replace rotors. thats it GG. just thought having flexible hoses would make everything just a bit easier. From the caliper to the strut should be rubber. http://www.ebay.com/sch/i.html?_from=R40&_trksid=p2050601.m570.l1313.TR0.TRC0.H0.X1980+datsun+210+brake+hose.TRS0&_nkw=1980+datsun+210+brake+hose&_sacat=0 There is a member here named hosestop@msn.com who makes stainless hoses for all things Datsun. From the caliper to the strut should be rubber. http://www.ebay.com/sch/i.html?_from=R40&_trksid=p2050601.m570.l1313.TR0.TRC0.H0.X1980+datsun+210+brake+hose.TRS0&_nkw=1980+datsun+210+brake+hose&_sacat=0 There is a member here named hosestop@msn.com who makes stainless hoses for all things Datsun. yup i was those, my question is that rear hose looks to be the one i want. is that rear hose male threaded end gonna fit into the front caliper. Quote Link to comment
ggzilla Posted April 18, 2015 Report Share Posted April 18, 2015 I have replace rotor without disconnecting the lines. They are not permanently attached to the struts, and will move out of the way. B310 (210) has a cutout in the bracket which allows movement of the line when the clip is removed. (on the left is B110 (1200), which has a solid bracket) Quote Link to comment
flatcat19 Posted April 18, 2015 Report Share Posted April 18, 2015 OH! I was wrong. I see what you mean now. Grab a bungee cord to hold the caliper out of the way after you LIGHTLY/SLOWLY remove it(the caliper.) Quote Link to comment
hosestop@msn.com Posted April 18, 2015 Report Share Posted April 18, 2015 HEh Flatcat your a Toyota guy , I always see them cut a slit in hardline to flex mount with a big pair of Dikes and bend holder and remove hose without breaking loose so as to let caliper hang , and can anybody say this guys name ? Quote Link to comment
COOCHaDAMus Posted April 18, 2015 Author Report Share Posted April 18, 2015 I have replace rotor without disconnecting the lines. They are not permanently attached to the struts, and will move out of the way. B310 (210) has a cutout in the bracket which allows movement of the line when the clip is removed. (on the left is B110 (1200), which has a solid bracket) thank you GG again for your knowledge my mane dammie. Quote Link to comment
flatcat19 Posted April 18, 2015 Report Share Posted April 18, 2015 HEh Flatcat your a Toyota guy , I always see them cut a slit in hardline to flex mount with a big pair of Dikes and bend holder and remove hose without breaking loose so as to let caliper hang , and can anybody say this guys name ? Currently a Toyota guy. But only by profession; not by enjoyment.Yes. Never bent a Tundra hose though. LOL. Quote Link to comment
