521 with VG30e. how to get speedometer to work?
accordfreak
  • Replies 9
Only speedo pinion from L series transmission built after '80 (may) fit the later 71C 5 speed. Get an early '87 and up D-21 Hardbody pinion. You will want a BLACK plastic, 17 tooth one to keep your speedometer accurate.
  • Like 4
The pinion sleeve will only fit the FS5W63A dogleg. The plastic pinion 'gear' from the F4W63 is too long to fit the later 71B or C transmissions.
521 on far left. Late ('80-) 71B. Early (-'80) 71B. Even the early and late 71B won't swap with each other.  The early and late 'gears' might swap haven't tried this.
