flatcat19 Posted April 13, 2015 Report Share Posted April 13, 2015 I don't own the truck yet, but title says it all. Going to go pick it up soon, but thats the description current owner is giving me. I plan on driving it home, 65 miles. I have no other option. Brainstorming session in 3...2...1... 1 Quote Link to comment
ggzilla Posted April 13, 2015 Report Share Posted April 13, 2015 Bring tool and back off the adjusters a bit. 2 Quote Link to comment
banzai510(hainz) Posted April 13, 2015 Report Share Posted April 13, 2015 bring a 11mm brake wrench or 11mm. I had on my 521 the master cyl would pump up and not release. I had to break the bleed and and make it home and I swapped ou the master cylinder and was fine. Bring tool and back off the adjusters a bit. Jack up truck and you can tell if dragging. 1 Quote Link to comment
MicroMachinery Posted April 13, 2015 Report Share Posted April 13, 2015 I've seen it happen where the little removable plastic strainer inside the MC can get pushed too far down, so it won't allow the fluid to return. As a result, the wheel cylinders can't immediately retract.. only after a "cooling down" period, the fluid slowly makes it's way back into the reservoir. Pretty odd situation that I chased around on a previous 521 I had. May not be your problem, but I HAVE seen it. 2 Quote Link to comment
flatcat19 Posted April 13, 2015 Author Report Share Posted April 13, 2015 Micro, sounds exactly like how owner described. I think it's a new master-i was thinking pushrod. But if only when hot, probably not. 1 Quote Link to comment
flatcat19 Posted April 13, 2015 Author Report Share Posted April 13, 2015 Micro, sounds exactly like how owner described. I think it's a new master-i was thinking pushrod. But if only when hot, probably not. 2 Quote Link to comment
banzai510(hainz) Posted April 13, 2015 Report Share Posted April 13, 2015 Most new master cylinders the rod has to be cut as its too long(non jap made units) thus pushing the master. I just installed a new master on my 521 last week 2 Quote Link to comment
laotsu Posted April 13, 2015 Report Share Posted April 13, 2015 I had this happen when I replaced my MC on Bleu. I had the pushrod adjusted wrong and as I used the brakes pressure would grow in the system. I just pulled on the brake pedal with the tip of my toe and it would relieve pressure. 1 Quote Link to comment
flatcat19 Posted April 13, 2015 Author Report Share Posted April 13, 2015 I'm going to be picking it up tonight. We'll see what happens. 1 Quote Link to comment
kelowg Posted April 13, 2015 Report Share Posted April 13, 2015 Had this happen with the rears,but i have dual master. something broke loose in the rear hose partly blocking line. 1 Quote Link to comment
ggzilla Posted April 13, 2015 Report Share Posted April 13, 2015 Also check the exhaust pipe. Maybe it runs too close to a brake line. 1 Quote Link to comment
Dolomite Posted April 14, 2015 Report Share Posted April 14, 2015 Partially frozen slaves? I had that happen on my 510 because I never adjusted them, after sitting they would free up a bit. 1 Quote Link to comment
flatcat19 Posted April 14, 2015 Author Report Share Posted April 14, 2015 Well, I have it. It doesn't look like either master has ever been replaced. Will replace both-but hesitant because I want discs. Oh well. 1 Quote Link to comment
Dolomite Posted April 14, 2015 Report Share Posted April 14, 2015 Congrats man. But...pics or it never happened! 3 Quote Link to comment
uberkevin Posted April 14, 2015 Report Share Posted April 14, 2015 Awesome man! 1 Quote Link to comment
ggzilla Posted April 14, 2015 Report Share Posted April 14, 2015 So did they lock up on the way home? 1 Quote Link to comment
flatcat19 Posted April 14, 2015 Author Report Share Posted April 14, 2015 Just got home. 65 mile drive. Did not lock up. I was running super warm the whole drive. Pop the hood when I got home-hoses are soft and squishy. No pressure. FML. I'll start a thread tomorrow. Too dark. No time for pics. Kevin has the solo pic I took since ownership. 1 Quote Link to comment
ggzilla Posted April 14, 2015 Report Share Posted April 14, 2015 Good news. So it seems the brakes are OK. 1 Quote Link to comment
flatcat19 Posted April 14, 2015 Author Report Share Posted April 14, 2015 This is from the Burger King window. I couldn't take my eyes off of it while the wife and kids were eating. 2 Quote Link to comment
ggzilla Posted April 14, 2015 Report Share Posted April 14, 2015 It's so little ... Quote Link to comment
flatcat19 Posted April 14, 2015 Author Report Share Posted April 14, 2015 It's so little ... Says the guy that has owned how many 1200s? Quote Link to comment
laotsu Posted April 14, 2015 Report Share Posted April 14, 2015 This is from the Burger King window. I couldn't take my eyes off of it while the wife and kids were eating. I'm stoked that you're stoked. 1 Quote Link to comment
flatcat19 Posted April 14, 2015 Author Report Share Posted April 14, 2015 I'm stoked that you're stoked. Maybe you'll want to check my dick out from now on? Quote Link to comment
laotsu Posted April 14, 2015 Report Share Posted April 14, 2015 nah, my candidate's dong is floppy enough for my tastes. Quote Link to comment
