Hayhayman Posted April 12, 2015 Report Share Posted April 12, 2015 I have a 1973 240z and i just put on new turn signal flasher and turn signal switch, but now the turn signals don't work anymore as they did before. The car as a lot of electrical issues but do you have any suggestions on how to fix this? thanks Quote Link to comment
datzenmike Posted April 12, 2015 Report Share Posted April 12, 2015 So they were working, but after the switch they are not working now? If so... Swap the old turn signal flasher unit back in.... does it work? Yes... problem splved No.... turn signal switch is the cause put the old one back in. Now post some pictures of your 240, and welcome to Ratsun. 1 Quote Link to comment
Hayhayman Posted May 23, 2015 Author Report Share Posted May 23, 2015 Sorry for the long delay. Put the old turn signal switch back on and it still didnt work. I think that im not getting any power to the turn signals. Also i bought a new harness and just put it in, so i might of hooked up the wrong wires? If it helps my hazards work fine too. Quote Link to comment
datzenmike Posted May 23, 2015 Report Share Posted May 23, 2015 On a hunch.... turn the turn signal on and switch the 4 way flasher switch on and off. Try moving the switch and see if this will get the turn signal working. Quote Link to comment
Hayhayman Posted May 23, 2015 Author Report Share Posted May 23, 2015 Just tried. Nothing. When you turn the turn signals on are you supposed to be able to hear the relay go on and off? Quote Link to comment
datzenmike Posted May 23, 2015 Report Share Posted May 23, 2015 If working you will hear the flasher unit clicking. You swapped the 4 way with the turn flasher unit? This would tell if the turn flasher unit was bad. Well time to get a $5 test lamp. This will tell you where the invisible electricity is hiding. Quote Link to comment
Hayhayman Posted May 23, 2015 Author Report Share Posted May 23, 2015 Tested the power to the turnsignal switch and I only got power when the hazard lights come on. Cross wired some where? Quote Link to comment
datzenmike Posted May 23, 2015 Report Share Posted May 23, 2015 No, the 4 way use the turn signal bulbs. You should have power at the flasher unit of the turn signals with the key on. Quote Link to comment
Hayhayman Posted May 23, 2015 Author Report Share Posted May 23, 2015 I'm not getting any power to the turn signal with the key on and are you saying test the power to all the bulbs? Quote Link to comment
datzenmike Posted May 23, 2015 Report Share Posted May 23, 2015 When the key is turned on power flows to half the fuse box. Through the signal fuse to the flasher unit and then to the turn signal. When the turn signal switch selects a turn, the power now flows to the proper signal lamps and to ground. When current flows, the flasher unit heats up and the contact opens and lights go off, it cools and re-connects, current flows and lights go on... this repeats until the turn signal is turned off. If you have no power to the flasher unit the fuse is likely blown or making poor contact. Quote Link to comment
DanielC Posted May 23, 2015 Report Share Posted May 23, 2015 On a 521, the fused turn signal power goes through the four way flasher when the four way flasher switch is off. I would think a 240 Z does the same thing. You should have power on one terminal of the turn signal flasher with the key ON. Use a test light to check. You should have power on one terminal of the four way flasher with the key OFF. Use a test light to check. Quote Link to comment
datzenmike Posted May 23, 2015 Report Share Posted May 23, 2015 Good point Daniel and why I suggested moving the 4 way switch around. The 720 switch will travel too far on the off position and actually disconnect the turn signals. You have to move the switch slightly towards the ON position to get them back. You might try switching the 4 way lamp switch on and off several times to clean the contacts. Quote Link to comment
Hayhayman Posted June 6, 2015 Author Report Share Posted June 6, 2015 Which one is the flasher unit? I think im just gonna replace it just for the hell of it. Quote Link to comment
datzenmike Posted June 6, 2015 Report Share Posted June 6, 2015 You swapped the 4 way with the turn flasher unit? This would tell if the turn flasher unit was bad. You're grasping at straws. Save the time, the money and the trouble and swap the 4 way and the turn signal flasher units. If nothing changes then it's NOT the flasher unit. Quote Link to comment
Hayhayman Posted June 8, 2015 Author Report Share Posted June 8, 2015 You're grasping at straws. Save the time, the money and the trouble and swap the 4 way and the turn signal flasher units. If nothing changes then it's NOT the flasher unit. do you have a link to a site that sells them? Quote Link to comment
