JmanTehan Posted April 11, 2015 Report Share Posted April 11, 2015 Hey guys, I have recently been replacing the head gasket on my 521 that has been used for a ranch truck for the past 25 years because I'm trying to turn it into my daily driver. I also put in new timing kit just cause i had it all out and open so why not. My issues are lying within putting the front cover back on. First off there are various bolts missing, so i am curious if i can get a kit with all of the bolts in it. The reason for wanting to replace all of the bolts is that i purchased a couple for the missing bolts but when i went to tourque the cover on i have broken two of the old bolts already. I have successfully gotten the broken bolts out because there was enough thread once i got the cover off to get them out and they both were finger tight. It is really getting very frustrating and now i am to the point where i just want all new bolts. Does anyone have information on all of the sizes or a kit i can purchase with all of the correct bolts in it? At this point i feel like everytime i touch a bolt on the cover it breaks. Am i being a dumbass and doing someone wrong? I am not experienced in this sort of thing what so ever so please tell me what i am doing wrong. Thanks guys! Quote Link to comment
datzenmike Posted April 11, 2015 Report Share Posted April 11, 2015 What year? If '70 and up it's an L series. Go to any wrecking yard and help yourself. Breaking them off could be using too long a bolt in a short bolt hole... some holes are blind and they will bottom out OR you are torquing them way too much. 8mm diameter 7-9 ft labs 6mm bolts 3-4 ft lbs. Quote Link to comment
ggzilla Posted April 11, 2015 Report Share Posted April 11, 2015 Most likely it is caused by corrosion of the steel bolt touching the aluminum cover. If you clean them up you can reuse the non-broken ones without issue. Nissan sells the correct bolts. Quote Link to comment
JmanTehan Posted April 11, 2015 Author Report Share Posted April 11, 2015 Yes it is a 1971 521 1600 with the L16 Thanks for the junk yard tip probably going to go see if i can find some here in a little bit! Yeah i was torquing them at like 3 pounds so I'm thinking and hoping its just the old bolts. Is there and actual set of bolts just for this or am i going to need to order them separately? I have been trying to post pictures but I cannot for some reason. It says that i am unable to post pictures in this community. Is this because i am a new member or am i missing something? Thanks guys This is awesome! Quote Link to comment
JmanTehan Posted April 12, 2015 Author Report Share Posted April 12, 2015 Just purchased a kit after searching for a lil while so now i guess I'm just waiting for the mail. Once again hahah Quote Link to comment
ggzilla Posted April 12, 2015 Report Share Posted April 12, 2015 If you purchase separately its like $5. But a kit is easier. Quote Link to comment
