icetitan Posted April 9, 2015 Report Share Posted April 9, 2015 Does anyone know what this piece is called or where you can get it ? (the view is from laying on my back under the front bumper looking up) . much thanks Quote Link to comment
datzenmike Posted April 9, 2015 Report Share Posted April 9, 2015 Bumper shock? Rad? valance? tension rod? sway bar? oil pan? Quote Link to comment
Guest Rick-rat Posted April 9, 2015 Report Share Posted April 9, 2015 That's the thingamajig, or the watchamacallit Picture would help Quote Link to comment
icetitan Posted April 9, 2015 Author Report Share Posted April 9, 2015 Oh sorry I thought I embedded a picture .. it didn't work it appears . Here it is as a link http://www.mediafire.com/view/5gf261e34id5b53/_IMG_0312.JPG Quote Link to comment
datzenmike Posted April 9, 2015 Report Share Posted April 9, 2015 RH steering knuckle. Quote Link to comment
q-tip Posted April 9, 2015 Report Share Posted April 9, 2015 RH steering knuckle. It be one of those. Quote Link to comment
ggzilla Posted April 9, 2015 Report Share Posted April 9, 2015 Steering Arm, which has no parts to wear out. Quote Link to comment
icetitan Posted April 10, 2015 Author Report Share Posted April 10, 2015 Thanks , well the mechanic who was going to so some front end work said the there was something wrong with it. He said it isn't tight (like the hole is too big or boared out or something). He recomended I find the part before he does the other work so he can do it all at once. Does anyone know if the part is manufactured still ? Might try posting in the classified section to try and find an old/used one. thanks everyone Quote Link to comment
datzenmike Posted April 10, 2015 Report Share Posted April 10, 2015 This is for a '78 280z??? 48510-E8700 is the RH side rod steering ball joint that fits into 40052-E4102 RH steering knuckle 48630-E8700 is the LH side rod steering ball joint that fits into 40053-E4102 LH steering knuckle If available the knuckles are about $60 each. You don't want to know what the side rods are worth. Quote Link to comment
icetitan Posted April 10, 2015 Author Report Share Posted April 10, 2015 thanks Datzenmike . Yes , for a '78 280Z. I'll look around. thanks for the parts numbers Quote Link to comment
Ratwagon1600 Posted April 12, 2015 Report Share Posted April 12, 2015 Down here, we call this a "steering arm". 1 Quote Link to comment
datzenmike Posted April 12, 2015 Report Share Posted April 12, 2015 There's no moving part on it and nothing to wear out. It's possible that the replacement ball joint shank is the smaller or the wrong one. Quote Link to comment
Stoffregen Motorsports Posted April 13, 2015 Report Share Posted April 13, 2015 Down here, we call this a "steering arm". Me too. Potato, patata. Quote Link to comment
