720 Light seals deteriorated, how to fix?
I've replaced both taillight lenses but the rubbergasket was in such a bad shape it fell appart when I unscrewed the lens. Same thing with the front indicators.
Are these available? Haven't been able to find any. Was thinking of using butyl rubber but that's just gonna be a mess everytime I a bulb needs changing.
Have any of you got any tips on getting these sealed again? It's on a 720.
  • Replies 2
Granted my car is a B210 not a 720, but with that said.  For seals on my rear tail lights I obtained some closed cell foam like is used for sealing doors on houses, from Ace Hardware to use.  Just cut it to size and inserted.  Not sure if that would work for you or not, but hope it helps.
