Apollo77 Posted April 2, 2015 Report Share Posted April 2, 2015 Anyone know what wire I need to put a load reducer on to be able to use led bulbs? 1 Quote Link to comment
kelowg Posted April 2, 2015 Report Share Posted April 2, 2015 For dash lights, u shouldnt need one. Load resistors r for turn bulbs to fool flasher can. Just get bulds rated for correct voltage 3 Quote Link to comment
620Turbo4X4 Posted April 3, 2015 Report Share Posted April 3, 2015 I just switched to led bulbs in my 620. I noticed when last bulb was switched that all of the LED's got dimmer. Also dimmer knob is either off or on now. I think this is because my truck does not use a rheostat and is rather PWM on the negative side and requires a certain amount of current to work properly. I've ordered up some can-bus bulbs. Let you know how this works out... PS. I just completed building a circut to invert the negative PWM to a positive PWM for aftermarket gauges that do not have a seperate ground for lighting. This fixes the problem of dash lights getting dimmer and gauges getting brighter when adjusting dimmer knob. If anyone is interested let me know and I might make up some more and post some in the classifieds. I have enough IC chips to make 9 more... 2 Quote Link to comment
ggzilla Posted April 3, 2015 Report Share Posted April 3, 2015 Most year 620s use an old fashioned rheostat. The last couple years they changed to what Datsun called a "semiconductor rheostat". 1 Quote Link to comment
620Turbo4X4 Posted April 3, 2015 Report Share Posted April 3, 2015 Good to know. All my trucks are 78's or 79's. The negative side pulse width modulation kinda sucks when you install aftermarket stereo, and gauges without the extra lighting ground. I couldn't find anyone that sells a inverter so your aftermarket stuff works right... 1 Quote Link to comment
