B210 Brake Lights
Kirden
Well, my B210 is up and running after sitting for 12 years, but I'm having an issue with the brake lights. They won't shut off. We've checked the fuses and all of them are good and corrosion free, but I don't know what all else needs to be checked. It's a 1977 B210 coupe.
  • Replies 7
There is a switch on the brake pedal box. The brake pedal has a small pad that pushes against the switch and opens the connection. The pad can fall off and the switch doesn't open.  Just tape something on it.
You guys were spot on. Got under there and the plug had been pushed through the hole, broken in three pieces. Replaced it with a penny and it's working perfectly now.
Now thats Ratsun Repair (or would that be redneck), either way; If it's crazy and it works, it ain't crazy.
