Forjen620 Posted March 26, 2015 Report Share Posted March 26, 2015 Hi everyone! I've got a couple small rust holes on the side of the bed along the seam. Can sheet metal be welded on the inside of the bed to patch it, then smoothed out on the outside? Quote Link to comment
datzenmike Posted March 26, 2015 Report Share Posted March 26, 2015 This seam is problematic because it's also where the bed surface meets the top and bottom side panel... and welcome to Ratsun. Quote Link to comment
Forjen620 Posted March 27, 2015 Author Report Share Posted March 27, 2015 What are my options? And thanks for the welcome! Quote Link to comment
Andres131313 Posted March 28, 2015 Report Share Posted March 28, 2015 It should. Just make sure you get a thick enough sheet. What I did for my 510 was take some wet sand paper, sand everything that is rust till its bear shiny steel. Then weld to it. Another way is to cut a square out to weld a matching square for an almost seamless job. The little holes 1/2 or smaller, and not in a critical structure part of the body I used an old school body shop technic of lead filling. Good luck and welcome! Bondo is not your friend. Quote Link to comment
Ratwagon1600 Posted March 28, 2015 Report Share Posted March 28, 2015 Pics? I can then give an opinion from thousands of miles away. Whatever you do, make sure you treat the rusted areas with a good quality rust conversion fluid/spray. Something like this should do the trick: http://www.speedwaymotors.com/3X-Chemistry-Rust-Converter-Aerosol-Spray-Can,80800.html Quote Link to comment
