H165 direct replacement?
agentwright007
  • Replies 17
I tried to put my H-165 behind my stock A15 and 5 speed tranny and it was a NO GO! The nose cone on the 165 rear end is about 3/4" longer. I could get one side of the 4 links to line up but not the other. Drive shaft was just a little too long.
turns out its a perfect fit. Wouldn't have known if it wasn't for "leosnake"... now I have a h165+rear disk brakes+rear sway bar sweet!!!
Pretty much a bolt n play I reuse my stock springs n shocks.. All the links are same length so it all worked for me
. Make sure to get the yoke for the dff side
Good on ya
You might have to shorten the driveshaft, which means a new shaft as the stock ones taper (are not resizable).
The main reason to go to S110 rear are to get the disc brakes, or to handle more torque (e.g.supercharged A15). But you can also fit the cheap ($800) TRD LSD units.
