Booniebashinbetsy Posted March 22, 2015 Report Share Posted March 22, 2015 I've got a 4wd 85 and I was just playing with the idea of swapping the front end for a solid axle set up. Just a thought, but dose anyone have any ideas on what kind of work that would take and ware would you start really? Quote Link to comment
datzenmike Posted March 22, 2015 Report Share Posted March 22, 2015 Yes it's a lot of work, about half just thinking about it and planning. What axle? Early Toyota 4x4? Really good disc brakes, same bolt pattern for the rims. Quote Link to comment
poor-mans-720 Posted March 22, 2015 Report Share Posted March 22, 2015 82 720 KC build threadhttp://community.ratsun.net/topic/37709-82-720-kc-build-thread/Started by poor-mans-720, Nov 22 2011 01:15 AMcheck this thread out... I SAS with both a D44 and Toyota still running the toy axle after 3 years. might go to tons some day 1 Quote Link to comment
]2eDeYe Posted March 22, 2015 Report Share Posted March 22, 2015 I would start with a tape measure and measure your frame and front axle to get some baselines. Early toyota axle, Late land cruiser axle (beef) or a Wagoneer dana 44 are all close to the same width as stock. What type of suspension your run is up to you to research. Leaf spring, radius arm, 3 or 4-link...coils and shocks, air shocks or coil over shocks are options. Then you need $, how much will depend on your previous choices. Other than that you will need a welder and some skills to do the swap. I would not suggest a suspension swap as a first or even 5th fab project, mistakes can be deadly. . That said read the thread in poor mans sig. The 4x4 620 thread in my sig might be helpful as well. Quote Link to comment
Guest Rick-rat Posted March 22, 2015 Report Share Posted March 22, 2015 Anything is possible 2 Quote Link to comment
thisismatt Posted March 22, 2015 Report Share Posted March 22, 2015 That guy should have simply named that the 244z, or 24x4z. 1 Quote Link to comment
