djwarp Posted May 19, 2017 Author Report Share Posted May 19, 2017 Hey Guys update on my truck i decided to go disc on the front. I had my grandpa out here helping me just need to install the reservoir. I have a question what kind of rims are a good fit for the truck? i want to go wide but not sure where to look for sizes and all that i tried google and some of the forums but every time i search for them i get 5 lugs. any feedback will be appreciated thanks. 1 Quote Link to comment
Charlie69 Posted May 19, 2017 Report Share Posted May 19, 2017 What disc brake kit did you buy. Mike klotz's kits allow running stock 14" wheels with an 1/8" spacer. Other kits requrire 15" or larger wheels to clear the calipers. Quote Link to comment
djwarp Posted May 21, 2017 Author Report Share Posted May 21, 2017 What disc brake kit did you buy. Mike klotz's kits allow running stock 14" wheels with an 1/8" spacer. Other kits requrire 15" or larger wheels to clear the calipers. I bought the kit from beebani I don't think they fit. 1 Quote Link to comment
wayno Posted May 21, 2017 Report Share Posted May 21, 2017 I have Mike Klotz disc brake kits on my 320s and I don't run any spacers with any 14 inch rims including the 320 rims, but I do have to knock down the high points on the inside of the 520/521/early 620 rims with a hammer, the 320 rims I have to grind a little off each rivet, the 14 inch 620 disc brake rims work without any changes. 1 Quote Link to comment
djwarp Posted June 24, 2017 Author Report Share Posted June 24, 2017 will these rims work ? Diameter: 16″ Width: 8″ Bolt pattern (PCD): 6×139.7mm Offset: 0mm Backspacing: 4.5″ Quote Link to comment
Stoffregen Motorsports Posted June 24, 2017 Report Share Posted June 24, 2017 Only one way to find out! They're probably too wide, but I don't know. I've never had a 521. They are cool wheels though. 1 Quote Link to comment
banzai510(hainz) Posted June 24, 2017 Report Share Posted June 24, 2017 I get more thums up with stock steelies painted white with stock caps why make this hard 2 Quote Link to comment
Charlie69 Posted June 24, 2017 Report Share Posted June 24, 2017 Thanks Charlie but i bought the haynes manual already. You will find that the FSM is much more accurate than any Haynes Manual, and all it takes is downloading it. I would suggest a thread title change as we are way past your fuel pum problem. I run stock wheels and tires on my trucks but I am old. 3 Quote Link to comment
hobospyder Posted June 25, 2017 Report Share Posted June 25, 2017 will these rims work ? Diameter: 16″ Width: 8″ Bolt pattern (PCD): 6×139.7mm Offset: 0mm Backspacing: 4.5″ they will on a 620. if someone brought a 521 i could tell you if they would work on a 521. but they do on a 620 1 Quote Link to comment
