510 2door Window Regulator
I'm trying to replace the "roller" in my driver window regulator.
The problem I've run into is: with the window rolled down, the regulator and window track are aligned properly. But with the window rolled up, the roller is about .25" off vertically, making the window sit a little forward.
Down:
16657358817_bbbda01509_z.jpgWindow Down by kamran zarrabi, on Flickr
Up:
16657358737_6e7f1dc354_z.jpgWindow Up by kamran zarrabi, on Flickr
Does anyone know a fix for this problem or should I just look for a new regulator?
Thanks!
  • Replies 6
The state of the window mechanism when I got to it was: the roller wheel had broke in half and was out of the track. The track had been bent back and duct-taped, I'm assuming to stop the vibration that occurred when I took the tape back off. The window was functioning fine with this "set up". I drilled out the roller and replaced it with a part that functioned seemingly perfectly once installed.
16659832587_5c88264380_z.jpgphoto 5 by kamran zarrabi, on Flickr
16679524368_485e7fd4f0_z.jpgphoto 1 by kamran zarrabi, on Flickr
However, when the window is rolled up;
16865974592_ed89d029c9_z.jpgphoto 2 by kamran zarrabi, on Flickr
it leans forward causing a gap between it and the door:
16841266596_a44f809a20_z.jpgphoto 3 by kamran zarrabi, on Flickr
I then removed the roller I installed and realized that once the mechanism was in the up position the roller and track were no longer aligned and the roller was pushing the window up and forward a bit.
Pic of car:
16680121600_268eb1e4d9_z.jpgphoto 4b by kamran zarrabi, on Flickr
