hatch Posted March 14, 2015 Report Share Posted March 14, 2015 have an 86 , 720 with z-24 engine , the coil to the exhaust? side does not fire , swapped coils they are ok , new ignition modules , the coil in question has a 3 wire connector , 1 wire red (i think) has power with key on other 2 wires are both grounded ... bad module ??? Quote Link to comment
datzenmike Posted March 14, 2015 Report Share Posted March 14, 2015 Change the first fuss on the far left hand side of the fuse box. Quote Link to comment
hatch Posted March 15, 2015 Author Report Share Posted March 15, 2015 fuses are good , i took the old 4 wire (intake ?) module connector apart eliminated tach wire reassembled to the 3 wire (exhaust?) and got coil to fire , now is back to original prob of stuttering and high rpm's under a load .. thought it was bad fuel or clogged fuel filter , changed that before the module , but no change ... looked for carbon tracks in dist cap too Quote Link to comment
datzenmike Posted March 15, 2015 Report Share Posted March 15, 2015 The four wire module is capable of having the exhaust side plugs shut off under heavy load. The three wire module has them firing all the time. Quote Link to comment
hatch Posted March 15, 2015 Author Report Share Posted March 15, 2015 ok , i'll get another module Quote Link to comment
datzenmike Posted March 15, 2015 Report Share Posted March 15, 2015 The only difference is the shutting off of the exhaust coil under heavy load. This was added later by Nissan to "reduce engine noise under load" so 3 wire should work just the same. Quote Link to comment
hatch Posted March 15, 2015 Author Report Share Posted March 15, 2015 so the modules are the same ? do you think i'm on the right path ? should i try another exhaust module ? Quote Link to comment
datzenmike Posted March 15, 2015 Report Share Posted March 15, 2015 Post three says you got coils working, so why change module? fuses are good , i took the old 4 wire (intake ?) module connector apart eliminated tach wire reassembled to the 3 wire (exhaust?) and got coil to fire , now is back to original prob of stuttering and high rpm's under a load .. thought it was bad fuel or clogged fuel filter , changed that before the module , but no change ... looked for carbon tracks in dist cap too The original problem (title) was coil not firing, now it's stuttering at high RPMs and load. Maybe start over with what the engine is doing right now. I realize new information changes things. Quote Link to comment
hatch Posted March 16, 2015 Author Report Share Posted March 16, 2015 it is and was originally stuttering at high rpm and under load . tried fuel filter first , them read through where people seemed to have same prob and decided to replace the modules , with new modules it ran worse - bad idle - found exhaust coil not firing , broke the original exhaust module so i adapted the old intake module to the exhaust coil and got spark back and i'm back to original problem of the stuttering at high rpm's and under load . Quote Link to comment
