Nissan Jam 2105
mrbigtanker
  • Replies 71
More license plates.what do you need now.
I can't find that roll of asbestos to put on the bottom side of the shield. I was going to look at the hardware store for some other heat barrier stuff. I also need to fix a fuel line that I installed for temporary use. Would like to insulate the fuel lines in the bay too. Front carb is also still off. Going to re-install it after I get the heat shield in place; it's already a PITA with the carb off.
Aaaaaaaaand it's dead. RIP L16.
I noticed a sweet fram on your engine.
If your engine doesn't idle high enough, your oil pressure will fall. Fix the idle and that leak, and I think you'll be fine. Stop running it with low oil pressure, though. That will kill it.
