theeoracle Posted March 9, 2015 Report Share Posted March 9, 2015 I have been searching all over the internet for information on my built in Datsun 510 steering wheel lock and i couldn't find any help. I read somewhere that an ignition key with one side means your car has a steering wheel lock. My key has one side so that means i geuss i have a steering wheel lock. I could only get it to lock twice by accident, I've tried hundreds of times. When i try to get it to lock i can't. Is there anyone who has a steering wheel lock that works and can help me please? Quote Link to comment
Laecaon Posted March 9, 2015 Report Share Posted March 9, 2015 Pretty sure all of the 70+ 510s have them... not sure on 68/69. Turn key all the way counter clockwise, like 180 degrees away from "off". Then turn steering wheel until it locks. I have an ignition lock not being used... Pretty simple device really. Quote Link to comment
ggzilla Posted March 9, 2015 Report Share Posted March 9, 2015 I read somewhere that an ignition key with one side means your car has a steering wheel lock. L Not true. Quote Link to comment
datzenmike Posted March 10, 2015 Report Share Posted March 10, 2015 C'mon guys. The '68 has the ignition switch on the dash to the left of the column. You know this. '69 was the first year the ignition was on the column... (not that it did or didn't have the lock feature) I would imagine if you have steering lock it will say LOCK on the ignition switch. 2 Quote Link to comment
qwik510 Posted March 10, 2015 Report Share Posted March 10, 2015 C'mon guys. The '68 has the ignition switch on the dash to the left of the column. You know this. '69 was the first year the ignition was on the column... (not that it did or didn't have the lock feature) I would imagine if you have steering lock it will say LOCK on the ignition switch. 68 has a key ignition built into the dash. 69 had a pod with the key ignition sw. added to the side of the steering column surround. It did not have a locking mechanism for the steering column. 70-73 had the locking steering column. You turn the key all the way off, remove the key and move the wheel left or right to engage the column lock. Quote Link to comment
Stoffregen Motorsports Posted March 10, 2015 Report Share Posted March 10, 2015 I had a locking type ignition switch that used a single sided key. I think it was a 1970 ignition switch and key. It had a chrome bezel too. Have you tried removing it from the column and inspecting it? How about lubricating it? Have you tried that? Quote Link to comment
theeoracle Posted March 14, 2015 Author Report Share Posted March 14, 2015 I haven't taken anything apart yet. I wanted to know a lil bit more about it b4 tearing it apart. Thanks guys. Quote Link to comment
Doctor510 Posted March 14, 2015 Report Share Posted March 14, 2015 I have been searching all over the internet for information on my built in Datsun 510 steering wheel lock and i couldn't find any help. I read somewhere that an ignition key with one side means your car has a steering wheel lock. My key has one side so that means i geuss i have a steering wheel lock. I could only get it to lock twice by accident, I've tried hundreds of times. When i try to get it to lock i can't. Is there anyone who has a steering wheel lock that works and can help me please? Make sure the key is removed, then turn the wheel 360*, it will not lock if it is left in the switch. Quote Link to comment
