Mr Big Tanker's watermelon wagon.
  • Replies 3.5k
I am liking your red interior more and more - normally I'm not a fan of red - in your wagon - wow.
Curious, what is the transmission tunnel shifter cover you have? Looks like a stock cover from some Datsun, I will need something for mine soon. Thanks.
I got a 620 cover as it’s longer and shaped to conform the tunnel and all good in the hood.and the stock rubber boot fits perfect. Almost like I know what I am doing.
wait till it’s done the interior will be cool.
Thanks, I jumped on fleabay and found one - so I snatched it. My shifter may be a bit farther back than yours but the cover plate is the biggest and closest fit I have seen - so I may need to mod it a bit. Looking forward to having the trans tunnel sealed up.
On 7/11/2021 at 9:24 AM, mrbigtanker said:
I believe its a 1/2 NPT plug. I have not looked at it in so long.
I take it you taped a thread in the part that feeds the heater coil to fit the plug, cool. Did you put a plug in the head where the connector is for the return to the head.
The passenger side of the hood needs a bit of love.  I'd check to see if the rubber cushion is possibly in wrong or interfering in some way.. It's sticking up quite a bit.
If not, I can help you go completely medieval on it.  We can show that bitch who's boss!
Looks great, regardless...
Edited by Duncan
  • Haha 1
rosso, FYI the 521 vs 620 vs 720 trans cover plates each have the shifter hole in a different location.  I think I have all three if pics & measurements would help!  PM if wanted!
TJ
7 hours ago, mrbigtanker said:
No its for a Z so they come threaded already. I think from the 260 or 260 Z.
........240Z is not a threaded water neck, we have a late 1977 280Z with the threaded water neck & I think the 280ZX is same..........??
