That4doorKiD Posted March 3, 2015 Report Share Posted March 3, 2015 68 510 cluster How can I test my LED bulbs in my cluster? They only flow one way. I marked which sides are + and - but what about the way i plug them on the dash? Any ideas Thx! Quote Link to comment
thisismatt Posted March 3, 2015 Report Share Posted March 3, 2015 On a lot of them there will be a common ground (-). Notice how one trace connects to a bunch of different bulb sockets - that's your ground assuming it's not a common hot for just the backlight for gauges. If you have a multimeter you can check as well. Pull off the harness plug and trace the hots vs ground. Quote Link to comment
That4doorKiD Posted March 3, 2015 Author Report Share Posted March 3, 2015 On a lot of them there will be a common ground (-). Notice how one trace connects to a bunch of different bulb sockets - that's your ground assuming it's not a common hot for just the backlight for gauges. If you have a multimeter you can check as well. Pull off the harness plug and trace the hots vs ground. Ok thanks for the help, do you know where I input the power to. End of the V. regulator maybe? 9v battery? Quote Link to comment
Skib Posted March 3, 2015 Report Share Posted March 3, 2015 plug it into the car and turn your light switch on? if they come on, theyre in right..... Quote Link to comment
DanielC Posted March 3, 2015 Report Share Posted March 3, 2015 If you can reach the lamp holders with the dashboard in the car, if they do not work, take the lamp holder out, turn it 180 degrees, and put it back in. Quote Link to comment
Fat510 Posted March 3, 2015 Report Share Posted March 3, 2015 You don't really need to test that. They only flow one way, so remember which way the sides were facing when you take them out, if they don't ,work flip the led around in the socket and try again they same way you took them out By the way... If you decide to led everything, i do not recommend the led 1157 type for your brake lights and blinkers. The resistor inside the light can't handle the power my car put out so it fried the resistor inside and the lights stopped working within a few hours. By few, I mean less than probably 4 hours. 1 Quote Link to comment
