AMK521 Posted February 26, 2015 Report Share Posted February 26, 2015 Ok so if there is a thread on this already feel free to just refer me to it but I didn't see one so here goes. I've started a ka24de swap in my 521 and the only mock up issue I have run into that isn't really easily overcome is the steering and the oil pan. Do I have any rear sump options or do I have to make my own pan? Quote Link to comment
flatcat19 Posted February 26, 2015 Report Share Posted February 26, 2015 Custom pan. Had you used a truck block, you would be set. You could flip the drag link(plenty of threads with people doing so in 620s) and grind down that crossmember bar that your KADE is currently resting against. 1 Quote Link to comment
AMK521 Posted February 26, 2015 Author Report Share Posted February 26, 2015 I might have left out a relatively important detail. I got a frame from a 79 620. Well the front half of a frame haha I'm doing a frame off and just using the front portion from the 620 to get the ball joint disc brake front end. So I don't seem to be having any crossmember issues at this point. I thought about flipping that drag link but the taper on the ball joints would be wrong. Don't people have issues with that? Quote Link to comment
flatcat19 Posted February 26, 2015 Report Share Posted February 26, 2015 Yes. They fill them in and redrill so the taper is underneath. The benefit to swapping the front half of the frame seems minimal to have ball joints. Beebani makes upper control arms for the kingpin trucks so you can have ball joints and hardbody spindles without all the work. $400, I think. PM here through here or find his listings all over eBay. Quote Link to comment
Stoffregen Motorsports Posted February 26, 2015 Report Share Posted February 26, 2015 It's not just gaining balljoints. There are many other benefits not the least of which is a more modern suspension geomoetry. The camber and caster gain have been greatly improved in the balljoint suspensions. The 320 I built with the 720 front clip was absolutely a blast to drive. Here's that build thread if anyone's interested. http://community.ratsun.net/topic/34698-320-balljoint-conversion/ It's not that difficult of a job. Quote Link to comment
Stoffregen Motorsports Posted February 27, 2015 Report Share Posted February 27, 2015 Custom pan. Had you used a truck block, you would be set. You could flip the drag link(plenty of threads with people doing so in 620s) and grind down that crossmember bar that your KADE is currently resting against. It seems a lot of people make this mistake. Truck motors are my choice always. 1 Quote Link to comment
ppeters914 Posted February 27, 2015 Report Share Posted February 27, 2015 I might have left out a relatively important detail. I got a frame from a 79 620. Well the front half of a frame haha I'm doing a frame off and just using the front portion from the 620 to get the ball joint disc brake front end. So I don't seem to be having any crossmember issues at this point. I thought about flipping that drag link but the taper on the ball joints would be wrong. Don't people have issues with that? Then you might want to review this thread: http://community.ratsun.net/topic/22191-1977-620-kingcab-deluxe/ Quote Link to comment
kelowg Posted February 27, 2015 Report Share Posted February 27, 2015 Car version should fit with its stock oil pan. I know of at least 2-3 that fit without mods. Quote Link to comment
flatcat19 Posted February 28, 2015 Report Share Posted February 28, 2015 The car pan fits onto the truck block, but not the other way. At least with the E. 1 Quote Link to comment
Farmer Joe Posted February 28, 2015 Report Share Posted February 28, 2015 okie dokie then.. just to clarify.. its a 521 body on a or with a late 620 frontend? correct? if thats so, then have the pitman and idler arm welded and retapered on the bottom side. flip the link after that. you might take a 1/4in off the topside of the engine crossmember to give it room. i would use ]2edeye's KA 620 mounts and see where that gets ya. Quote Link to comment
mrbigtanker Posted February 28, 2015 Report Share Posted February 28, 2015 So guys have used the stock KA mounts withy he 521 rubber mount portion and have just about lined up to factory frame mounts. The blocks are very close. Quote Link to comment
uberkevin Posted March 1, 2015 Report Share Posted March 1, 2015 I believe I've seen a thread here where i guy used the 240sx mounts in his 521.. its now a dead thread now but I doooo think theres photos.. Quote Link to comment
datzenmike Posted March 1, 2015 Report Share Posted March 1, 2015 The car pan fits onto the truck block, but not the other way. At least with the E. On the KA24E this is true. The car DE has an internal oil pump while the truck DE is external just like the L and Z series engines. These oil pans are differently shaped at the front where they mate to the block/timing cover and will not swap. 1 Quote Link to comment
uberkevin Posted March 5, 2015 Report Share Posted March 5, 2015 http://community.ratsun.net/topic/58207-project-ka24-521/ Quote Link to comment
TENDRIL Posted October 1, 2015 Report Share Posted October 1, 2015 On the KA24E this is true. The car DE has an internal oil pump while the truck DE is external just like the L and Z series engines. These oil pans are differently shaped at the front where they mate to the block/timing cover and will not swap. so could you take the pan and front cover from a truck DE and swap onto the car DE in order to get the external oil pump? ? this is regarding the ka in my 510 btw with an already flipped x-member? i have a 240sx ka24de, and to replace the oil pump/timing cover is about 400$, with the truck cover they are a quarter of that Quote Link to comment
