HOGIE Posted May 6, 2016 Author Report Share Posted May 6, 2016 Last we got a lot of things done. I buttoned up a bunch of the minor yet important details and Al spent the whole time aging detective trying to figure out what PO did to the electrics. It turns out that the ignition switch is correct and they wired around it somehow. This means for now it's getting a push button starter switch, tonight. It will start tonight. Then more brake work and exhaust and it will be a driver. 4 Quote Link to comment
uberkevin Posted May 6, 2016 Report Share Posted May 6, 2016 For some reason I don't believe a word your saying!! 2 Quote Link to comment
DanielC Posted May 6, 2016 Report Share Posted May 6, 2016 I have probably thrown this out to you before, but here it is again. Start circuit is really simple. A thick white wire from the battery side of the fusebox goes to the ignition switch. The ignition switch connects a black wire, with a yellow stripe to the power when cranking, that wire goes to the starter solenoid, small terminal. If you have ignition power, half of the start circuit is already done. 2 Quote Link to comment
HOGIE Posted May 6, 2016 Author Report Share Posted May 6, 2016 For some reason I don't believe a word your saying!! It's because of the lack of photos isn't it? 4 Quote Link to comment
HOGIE Posted May 6, 2016 Author Report Share Posted May 6, 2016 I have probably thrown this out to you before, but here it is again. Start circuit is really simple. A thick white wire from the battery side of the fusebox goes to the ignition switch. The ignition switch connects a black wire, with a yellow stripe to the power when cranking, that wire goes to the starter solenoid, small terminal. If you have ignition power, half of the start circuit is already done. Your right, the start circuit is simple. The problem is that the ignition switch that came to me in the truck, and it's the only one I have at this point, only has OFF and POWER positions. And to try to get this to work the PO made 'things' happen. Those 'things' are all wrong. When I can get my hands on the correct switch it will all go back to where it should be. For now it gets a push button start switch. I need to print that diagram out in large print. Some said they did that and it sounds like an awesome idea 1 Quote Link to comment
pablo Posted May 7, 2016 Report Share Posted May 7, 2016 you gonna be around Al's tomorrow? 1 Quote Link to comment
flatcat19 Posted May 7, 2016 Report Share Posted May 7, 2016 This thing running yet? 1 Quote Link to comment
HOGIE Posted May 7, 2016 Author Report Share Posted May 7, 2016 you gonna be around Al's tomorrow? I've got family duties, nope 1 Quote Link to comment
HOGIE Posted May 7, 2016 Author Report Share Posted May 7, 2016 This thing running yet? Nope. Spent almost the whole night working on taking the brakes apart. Wheels cylinders are pretty bad. Once the brakes are fixed getting the engine running will happen. Can't drive with no brakes I did get all the wheel cylinders to come apart. Won't get around to doing anything this weekend but next week I'm taking the drums to get turned and rebuild the adjusters and clean up the wheels cylinder pistons. These need help 2 Quote Link to comment
flatcat19 Posted May 7, 2016 Report Share Posted May 7, 2016 I just did all of that to mine. Every serviceable piece replaced. Rebuilding the adjusters was the shittiest part. If yours are anything like mine you'll be in it for a few hours. Yuck. 2 Quote Link to comment
HOGIE Posted May 7, 2016 Author Report Share Posted May 7, 2016 I just did all of that to mine. Every serviceable piece replaced. Rebuilding the adjusters was the shittiest part. If yours are anything like mine you'll be in it for a few hours. Yuck. Yuck is right. Dried out grease, brake dust build up and rust. I plan to have everything cleaned up and reinstalled by Wednesday night. Engine running, rolling and braking properly. Over the next few day I'm going to put the heart box all back together too 2 Quote Link to comment
flatcat19 Posted May 8, 2016 Report Share Posted May 8, 2016 Yuck is right. Dried out grease, brake dust build up and rust. I plan to have everything cleaned up and reinstalled by Wednesday night. Engine running, rolling and braking properly. Over the next few day I'm going to put the heart box all back together too Have you gotten the adjusters apart yet? 3 Quote Link to comment
KoHeartsGPA Posted May 9, 2016 Report Share Posted May 9, 2016 I used a small torch and sprayed with wd40 to get mine loose, that's the hardest part, they'll clean up fine.. After clean up.... 1 Quote Link to comment
flatcat19 Posted May 9, 2016 Report Share Posted May 9, 2016 Way different for a 521. Lots of PB and a hammer. 4 Quote Link to comment
flatcat19 Posted May 9, 2016 Report Share Posted May 9, 2016 The star wheel/sleeve was the hardest part and all 4 were equally bad. Get some round metal brushes to clean all the tubes when apart. Couple bucks from Home Depot. Wire wheel the threaded rod. Lots of anti-seize on everything. And mark them all. Left and right matter. Front to rear do not. 3 Quote Link to comment
HOGIE Posted May 9, 2016 Author Report Share Posted May 9, 2016 I did already get both of the front adjusters apart last week. Haven't done anything with the truck this weekend. Bunch of this They all have been covered in PB for the last few days. Wheel cylinders are soaking in WD. Tomorrow or Tuesday the plan is scrub up rusty shit and get wheels turned. Gonna stop like a mutherfucker 6 Quote Link to comment
DanielC Posted May 9, 2016 Report Share Posted May 9, 2016 Left hand thread adjusters go on the left. 2 Quote Link to comment
HOGIE Posted May 9, 2016 Author Report Share Posted May 9, 2016 Left hand thread adjusters go on the left. Thanks Daniel. I seperated front from back but not left from right. Left threads left side. Makes intuitive sense 3 Quote Link to comment
DanielC Posted May 9, 2016 Report Share Posted May 9, 2016 Like it was said before, front and back ironically does not matter. The left and right side is really not that important, if put on the wrong side, you just have to remember to turn the star wheel the other way to adjust the brakes tigher. 2 Quote Link to comment
HOGIE Posted May 10, 2016 Author Report Share Posted May 10, 2016 who has the specs for the maximum turnable diameter for 521 brake drums? I don't have a 521 SM and google hasnt helped yet Edit: Figured it out. 255.5mm or 10.06" 521 Brakes http://vintage.mitchell1.com/PClubData/chassis/chis73/V2I737046.pdf 521 Service Manual http://www.datsun510.com/manuals/Service_Manual_Datsun_Pick-Up_Model_521_Series_Chassis_and_Body.pdf 2 Quote Link to comment
Charlie69 Posted May 12, 2016 Report Share Posted May 12, 2016 Draker that picture looks like a wiener in a bun! LOL Here is a Hoagie! LOL After researching "Hoagie" pretty much anything put in a hoagie roll/bun is a hoagie. 1 Quote Link to comment
KoHeartsGPA Posted May 13, 2016 Report Share Posted May 13, 2016 Datsun 411 is also a hogie....well....They look like one... Quote Link to comment
