Kulper620 Posted February 18, 2015 Report Share Posted February 18, 2015 was wondering if anyone knew where i can source one of these headgaskets for an o-ringed block, i cant seem to have any luck finding one. if anyone knows any old timer datsun holics that mite be holding on to a few let me know please, ill post pics of the fresh block after its out of the machine shop Quote Link to comment
Stoffregen Motorsports Posted February 18, 2015 Report Share Posted February 18, 2015 You can use a stock Nissan gasket with an o-ringed block. HKS made a layered steel gasket. Is that what you're thinking of? I would use an OEM head gasket. 1 Quote Link to comment
banzai510(hainz) Posted February 18, 2015 Report Share Posted February 18, 2015 maybe this will work, most likely stock http://www.courtesyparts.com/head-gasket-p-622284.html Quote Link to comment
Kulper620 Posted February 18, 2015 Author Report Share Posted February 18, 2015 This is the gasket I'm looking for, I don't think I can use a stock headgasket with this setup, there would be an issue with the o-ring since it sits in the block Quote Link to comment
Kulper620 Posted February 18, 2015 Author Report Share Posted February 18, 2015 This is what my block looks like, it has been groove for the o-ring setup so I don't blow headgaskets with a turbo Quote Link to comment
banzai510(hainz) Posted February 18, 2015 Report Share Posted February 18, 2015 maddat datsport both austrialia 1 Quote Link to comment
datzenmike Posted February 20, 2015 Report Share Posted February 20, 2015 This is not the usual method of O ringing a block. I guess a flattened ring would work also. 1 Quote Link to comment
Kulper620 Posted February 20, 2015 Author Report Share Posted February 20, 2015 This build was begun in the 80's and went by the way they had it in frank honsowetz book, the gaskets and o rings were readily available through nissan motors ports then, this why I'm having issues finding a gasket Quote Link to comment
TFM1066 Posted February 20, 2015 Report Share Posted February 20, 2015 That’s so old, even Nissan wouldn’t do that way today, throw the block away and get another one. There is no way you could be making enough compression to need that with flat top pistons. Quote Link to comment
datzenmike Posted February 20, 2015 Report Share Posted February 20, 2015 o-ring headgasket 111044-u0825 for my l20b turbo motor A turbo changes everything.... 2 Quote Link to comment
Stoffregen Motorsports Posted February 20, 2015 Report Share Posted February 20, 2015 I've done plenty of blocks with o-rings, but I've always used annealed wire. I would seriously start looking for another block. Bore and hone is not expensive and block prep is kind of fun so it's not a total loss. Besides, I bet you could sell that block to some vintage racer. Quote Link to comment
Kulper620 Posted February 20, 2015 Author Report Share Posted February 20, 2015 Starting a new block makes no sense to me, it had a lot of work done to it while some old tech was used its still just as good, sent my old gasket to cometic gaskets in Ohio and they are making me one for $89, works for me 1 Quote Link to comment
Stoffregen Motorsports Posted February 21, 2015 Report Share Posted February 21, 2015 Well if that's the case, go for it. If you couldn't have found a gasket, I think a new block would have been your only option. Quote Link to comment
Kulper620 Posted February 22, 2015 Author Report Share Posted February 22, 2015 http://i968.photobucket.com/albums/ae170/kulperj/Mobile%20Uploads/CF39F340-8E83-44CD-B89A-4CA5EF89A262_zpsphih9xts.jpg Quote Link to comment
Stoffregen Motorsports Posted February 22, 2015 Report Share Posted February 22, 2015 Yay, pics! Of what? 1 Quote Link to comment
thisismatt Posted February 22, 2015 Report Share Posted February 22, 2015 Valve spring helpers? Quote Link to comment
Kulper620 Posted February 22, 2015 Author Report Share Posted February 22, 2015 The exhaust valve in this head is higher than the intake and I have the adjuster all the way down and there is absolutely no gap for valve adjustment Quote Link to comment
Stoffregen Motorsports Posted February 22, 2015 Report Share Posted February 22, 2015 Are the seats trashed? Obviously you've tried different lash pads...right? Was that head built around that cam? Valve tip lengths are ground specifically to help set up the rocker geometry. Quote Link to comment
Kulper620 Posted February 22, 2015 Author Report Share Posted February 22, 2015 Before machine shop Quote Link to comment
Kulper620 Posted February 22, 2015 Author Report Share Posted February 22, 2015 Quote Link to comment
Kulper620 Posted February 22, 2015 Author Report Share Posted February 22, 2015 After Quote Link to comment
Kulper620 Posted February 22, 2015 Author Report Share Posted February 22, 2015 1 Quote Link to comment
Kulper620 Posted February 22, 2015 Author Report Share Posted February 22, 2015 Seats look brand new and lash pads and can came with the head already assembled, took it apart to clean the little surface rust in the cam lobes and when I started to put the rockers in I noticed the exhaust one weren't tapping in easy, then I noticed that the exhaust valve springs were a little taller then the intake and with the adjuster screw all the way down I can't even get the smallest feeler guage through it Quote Link to comment
