Datsun510Boy Posted February 12, 2015 Report Share Posted February 12, 2015 Headlights an tail lights work so does turn signals . But no brake lights or reverse light so I'm going to start with the bulbs then inspect and clean the fuse box Later soak in vinegar like everyone says and scrape with a Brush . Quote Link to comment
Dolomite Posted February 13, 2015 Report Share Posted February 13, 2015 Do the vinegar soak, it worked wonders for my side markers and signals. Replace all fuses, even if they look good they can be bad, I had issues with proper looking blown fuses. Years of heat cycling can crystallize the metal and it won't conduct properly. Check out the reverse light wires to the trans, I believe they are red with black. Quote Link to comment
Datsun510Boy Posted February 13, 2015 Author Report Share Posted February 13, 2015 ok i got everything to work brake lights tail and headlights . it was a matter of adjusting the fuses twisting them into a different position . so it was the fuse box needs to be cleaned . i took it off to soak but there are wires that don't disconnect in the back should i soak those too? the whole fuse box ? Quote Link to comment
TENDRIL Posted February 13, 2015 Report Share Posted February 13, 2015 Yes submerg for about 15-20 min, than rinse with water. I than would dry it out with a hair dryer or sorts. And if you wish put some electrical grease with a q-tip on the insides where the fuses touch Quote Link to comment
Datsun510Boy Posted February 13, 2015 Author Report Share Posted February 13, 2015 okay thanks I'm doing that now Quote Link to comment
TENDRIL Posted February 13, 2015 Report Share Posted February 13, 2015 You can pretty much do that to the head light plugs and other connections as well if needed, less resistance brighter lights Quote Link to comment
Datsun510Boy Posted February 16, 2015 Author Report Share Posted February 16, 2015 worked like a charm! lights brighter all signals work 2 Quote Link to comment
MikeRL411 Posted March 11, 2015 Report Share Posted March 11, 2015 A bit late now, but it is a good idea when you remove and reinstall a fuse box to cut a patch out of a plastic milk or juice container and install as an insulating wafer under the fuse box. I had a piece of debris slip under mine and short to ground melting a hole in the fuse box cover. Quote Link to comment
