My First Project- 68 4 door
  • Replies 110
You have stock struts... Look at your 7" wide front wheel. Think about how much more an 8" would poke out, especially with negative offset, and a slightly taller tire. You'd have no room to go any lower without filleting your tire, and/or an absurd amount of negative camber. You should work on finding 280zx struts/brakes. Narrow your front track, and more importantly, have better brakes. Some things are more important than others. Prioritize.
True, maybe 8 0offset will do
I think swaztikas only go good on two doors, when they have Supersonic Grills
Swastikas on four doors are a no no
He's correct man, get you a set of 280zx struts and your good to go. You'd be able to get 8" wide in the front no problem, I'm 8" with no offset in the rear. I could of done the same for the front but I wanted to stagger for a certain look, if you don't go 280zx you will def poke going wider than 7"
