Janksun Posted February 3, 2015 Report Share Posted February 3, 2015 I've noticed that my rear end has been whining a lot lately and it keeps getting worse. It does leak and I top it off every now and then but it just keeps getting worse. It's a 1971 510 wagon that was an auto. I haven't taken it apart yet because it's my daily driver. I was wondering if there's a way to adjust the clearances or is it toast? I also noticed that there is a little slop in the driveshaft to axle play, like I could spin the driveshaft and the wheels wouldn't turn right away, is that normal? Quote Link to comment
kelowg Posted February 3, 2015 Report Share Posted February 3, 2015 Maybe pinion nut has backed off. Pretty much a rebuild to adjust it. Look at the gears thru fill and drain holes,if teeth look ok then likely bearings. Those r pressed on i believe. Quote Link to comment
flatcat19 Posted February 3, 2015 Report Share Posted February 3, 2015 Drain fluid into a pan. Inspect fluid for metal shavings/sludge. Start shopping. 1 Quote Link to comment
