Cruzn620 Posted January 30, 2015 Report Share Posted January 30, 2015 I've completed my KA24E swap into my truck, but I need to wire the new fuel pump up. I'm using the ENTIRE hardbody wiring harness, and I'm going to ground the pump to the frame. Now, I ran across this wiring diagram which is supposed to be for my wiring harness... However, when I looked at my harness, here is what I had plugging into the fuel pump. None of the colors match. Anybody have ANY idea which ones are switched power that I can use to power the pump when I flip the key? Link to comment
datzenmike Posted January 30, 2015 Report Share Posted January 30, 2015 http://community.ratsun.net/topic/65287-ka-engine-swap-fuel-pump-wiring/?do=findComment&comment=1203479 You already have a post on this!!! Make the best of it! Link to comment
