JMAYHALL Posted January 29, 2015 Report Share Posted January 29, 2015 Does anyone know of an upgraded steering box that would fit a 76 B-210? Or maybe a rebuild kit for the one I have? Thanks, Jeff Quote Link to comment
datzenmike Posted January 30, 2015 Report Share Posted January 30, 2015 Modified your title so not everyone has to open it to find out it's only for B-210 owners. Would appreciate a little thought into titles. The B-210 and the old 510 had similar parts in them that are NLA (bearings and gears) the A10 has a similar box and while not an up grade could possibly be swapped into the B Quote Link to comment
datsunfreak Posted January 30, 2015 Report Share Posted January 30, 2015 Modified your title so not everyone has to open it to find out it's only for B-210 owners. Would appreciate a little thought into titles. The B-210 and the old 510 had similar parts in them that are NLA (bearings and gears) the A10 has a similar box and while not an up grade could possibly be swapped into the B The '79-83 210 box can also be used in a B210. Does anyone know of an upgraded steering box that would fit a 76 B-210? As for an "upgrade", it depends on how you define upgrade. There are other options for different ratios, but if strength is your concern, none are stronger. Quote Link to comment
JMAYHALL Posted January 30, 2015 Author Report Share Posted January 30, 2015 My apologies for the title, that makes sense. So, the steering box is a good one. I have 7 inch wide tires on the car and it’s a hand full to keep straight with the sloppy steering. Do they still make rebuild kits for the box? And are there kits for the rest of the steering linkage? Thanks Quote Link to comment
datsunfreak Posted January 31, 2015 Report Share Posted January 31, 2015 Do they still make rebuild kits for the box? And are there kits for the rest of the steering linkage? No to the first. Yes to the second. Quote Link to comment
