ZXguys...whose coil over
Z-train
  • Replies 4
Strut tubes are 2" diameter.
A narrower coil will leave more room for tire clearance and camber adjustment (if using adjustable camber plates) than a wider one.
All things equal,..(wire diameter and number of coils) a narrower coil will have a higher spring rate than a wider diameter coil..
