Throttle cable
Scgreen620
Can any one show me your throttle cable wiring I've seen some that have nuts that hold it together but I don't have that ... I know the question is dumb but I only have tape holding my throttle cable the one that connects to the carb I have a weber carb .. Any help works I looked online but there are no good pictures thanks
  • Replies 9
I have a post somewhere with some oics. You might search on my "started threads etc." bs's.
There's also mention of me using a speaker wire for a throttle cable, pulling on it out the window (not safe). But I made it 2 miles to my house.
I apologize man, I misunderstood your question (not much sleep lately). If you're asking about how it secures to the firewall...I believe early ones have the nut you mentioned and the later ones use 2 10mm bolts to the firewall. Like what Charlie69 posted above.
