JW360 Posted January 21, 2015 Report Share Posted January 21, 2015 As far as I know all thats needed is engine mounts, relocate oil pan, and custom drive shaft? Is this correct and does anyone have a mock up of the mounts or sell them? This is for an 82 720 Quote Link to comment
]2eDeYe Posted January 21, 2015 Report Share Posted January 21, 2015 No mounts for the 720 KA swap that I know of. I've been trying to work with a couple 720 guys to develop some mounts but no luck as of yet. Haven't heard of the oil pan needing modification. The drive shaft will need modified (shortened) if you use the KA transmission. Quote Link to comment
JW360 Posted January 21, 2015 Author Report Share Posted January 21, 2015 So just shortened I can keep my original drive shaft? Yeah its the KA transmission. Quote Link to comment
]2eDeYe Posted January 21, 2015 Report Share Posted January 21, 2015 Yep shorten the 720 drive shaft. Noot sure on how much, you will want to take your own measurements to be sure. Quote Link to comment
JW360 Posted January 21, 2015 Author Report Share Posted January 21, 2015 Sweet thanks Quote Link to comment
petercscherer Posted January 21, 2015 Report Share Posted January 21, 2015 The only modifications needed to the oil pan is if you get the KA24 from a car. The car models have a front-sump pan that will interfere with 720's crossmember, but the truck KA24 has the correct rear-sump. From my research, truck motors are a bit harder to find, but the truck pan/pickup-tube can be adapted to any car KA. There are some very experienced members here who have done this swap before and they may chime in with more information and advice. ~Peter Quote Link to comment
JW360 Posted January 21, 2015 Author Report Share Posted January 21, 2015 Yeah the one I am looking at is a car KA Quote Link to comment
Lockleaf Posted January 21, 2015 Report Share Posted January 21, 2015 Don't forget you need a rear sump oil pickup tube to go with the rear sump oil pan. Quote Link to comment
heretic Posted January 21, 2015 Report Share Posted January 21, 2015 ........ the truck pan/pickup-tube can be adapted to any car KA.... I could not find a clear answer on that.. I think its the other way around because the car KA has a crank girdle that will interfere with the D21's shallow pan, in other words a (deeper) car pan can be used on a truck motor.... personally I held out until I found a rear sump D21 KA. 1 Quote Link to comment
petercscherer Posted January 21, 2015 Report Share Posted January 21, 2015 I could not find a clear answer on that.. I think its the other way around because the car KA has a crank girdle that will interfere with the D21's shallow pan, in other words a (deeper) car pan can be used on a truck motor.... personally I held out until I found a rear sump D21 KA. Well you may be right, I've researching this swap for quite awhile now and some builders have gone both ways. I would link to their build-threads, but I don't want to get cited for advertising. Either way, modifications WILL be necessary to get any KA pan to work in a 720. ~Peter Quote Link to comment
heretic Posted January 21, 2015 Report Share Posted January 21, 2015 Well you may be right, I've researching this swap for quite awhile now and some builders have gone both ways. I would link to their build-threads, but I don't want to get cited for advertising. Either way, modifications WILL be necessary to get any KA pan to work in a 720. ~Peter For sure. Quote Link to comment
]2eDeYe Posted January 21, 2015 Report Share Posted January 21, 2015 Well you may be right, I've researching this swap for quite awhile now and some builders have gone both ways. I would link to their build-threads, but I don't want to get cited for advertising. Either way, modifications WILL be necessary to get any KA pan to work in a 720. ~Peter Link away, we are all about learning from others here. :) Quote Link to comment
petercscherer Posted January 21, 2015 Report Share Posted January 21, 2015 Well, for the sake of knowledge then: Custom Pans http://forums.nicoclub.com/ka24e-swap-85-720-4x4-t503290.html http://720world.com/forum/topics/ka24de-into-720?id=2016119%3ATopic%3A82237&page=1#comments Helpful General Links http://www.northwestnissans.com/board/threads/116544-Ka24de-swap-into-Nissan-720-truck-*need-help* http://720world.com/forum/topics/ka24e-swap?x=1&id=2016119%3ATopic%3A11286&page=1#comments http://720world.com/forum/topics/2016119:Topic:686?commentId=2016119%3AComment%3A691 http://community.ratsun.net/topic/19011-ka24e-or-de-into-1984-nissan-720/ ~Peter Quote Link to comment
JW360 Posted January 22, 2015 Author Report Share Posted January 22, 2015 Yay ok cool Quote Link to comment
