ericsb210
  • Replies 20
I've never seen original bucket seats. I'm not sure it was an option. I've seen somebody put 240z/280z buckets that looked right at home in there.
I believe bucket seats were standard on the '76-'79 KCs as well as the Cab and Chasis models.
I have the carb air box and 3 hubcaps. Might have more parts. Good luck on the bucket seats. Hard to find. They are out there. Think only the automatics had bench seats. Standards had a rear center console piece between seats.
Also, is the front brake disk conversion important? Or are the front drums adequate?
The drums are just fine for them, but if you do plan on upgrading anything power wise, I would do the brakes... hell i'd do the brakes anyway. But it isn't NEEDED. Everything SHOULD be able to swap straight over from a 78-79.
Hope this helps :D
