Green Machine
russaroll
  • Replies 107
Wow- you don't screw around, do you? You've made more progress on this one in four months than I've managed to make on any of my projects in as many years.
I try to do something every week. Even if it's just for an hour or two. My goal was to have it ready by June but, lack of muny is slowing me down.
thought i would do a little more today before i migrate to the couch.
pulled some stuff off the front
pulled the exhaust mani
then i found this
there seems to be some heavy crust buildup goin on.  looks like i'll be pulling the head and getting it tanked.
pile of parts
got a little more done this weekend.
i pulled the pan and checked the bearings.  the looked good, just some normal wear.  (no oics of bearings:(  )
intake is off
popped it's lid
17106506369_af4841c4c8_h.jpg[
cams out.  going to swapping them out with Tomei 256
pulled the head for some cleaning action
some parts came in
whats in the box?.
every gasket i could ever want.
greddy RAS
t-stat
  • 3 weeks later...
so i got her on the ground this morning.  woohoo.
i was going to roll out and blow some of the dirt a shit out of the inside when i discovered this.
rubbin'.  i think i need to raise it up some so it can roll.  the tires on these rollers have some bulging sidewall.
  • 4 weeks later...
  • 3 weeks later...
this week was good.  i got the head back from the machine shop.
head studs came in.
the rubbing issue is no longer an issue.  i bought these mesh wheels for my wagon a couple years ago and never got around to using them.  now they have a temp home and some fresh rubber (until i destroy them  :devil: )
155/55 r14 Formoza on 14x6.5 or 7.  not sure
not ride height but not all the way down.  still have a little over an inch to go.
turbo mani came in friday. cx racing.   i'm real surprised i got it.  i woke up this morning to make a delivery for work and it was sitting by the door.  the doorbell never went off, nobody knocked, i never even saw the fed ex man.  :no:
looks like it was well made.
time to get down to business.
cleaned surface
studs in
heads on
greddy ras on
VC on.
i know it's rough but, oh well.  i just want it to go.  i don't care about show.
peek-a-boo
just a mock up for a nice photo op.  i still need to get new ex studs and other misc hardware.
until next time.
  • 1 month later...
did some stuff.  mounted the intercooler this weekend.
like a glove.
there's just enough room on the bottom to get my hoses ond clamps on.
i've also been battling this greddy im i ordered.  the first one they sent was for the N15 tb not the stock tb.
no worky :(
the guy i ordered it from was real cool and exchanged it.  now the fuel rail won't line up.
Great progress !
Thanks
Damn you're working fast. Love the ground up approach with all the detail on your suspension refurbish. When you're done you should start to take it out to some of the autocrosses at the Santa Maria airport. There are a couple of us Datsun heads that go to the ones the PCA holds.
Thanks. It doesn't seem fast. I knew they ran go karts out there, never knew about autoX
Nice... wish I have your skills and space... Hate this HOA horse shit#!!
thanks.  would you believe that this is my first swap?  well second actually.  put a L20b in my wagon.  i just do lots of research on different forums, other peoples builds, google, youtubes.
  • 1 month later...
didn't do much today.
plumbed the turbo, kind of.  i need to get a 90 or a longer hose for the water out.
v-band flange is on for the down pipe.
maxworx fuel rail mocked up.  it was the only thing i could find that would fit the new style greddy manifold.  the injectors i have won't work with this fuel rail :(  time to order another set.
  • 1 month later...
iv'e been kind if busy.
cleaned, repainted, and new seals on the diff.
just in case rockauto doesn't have any.  i had to get these from o'reillys.
it doesn't look it but, it is cleaner
this is the first time the car has seen the outside since i first brought it home.
wats going on here?
spec stage2
it's in, it's in.  kind of blurry though
it's a tight fit.  i think i'll have to push the back of the motor down to get the trans on.
bonus pic
