bucketoval Posted May 29, 2007 Report Share Posted May 29, 2007 does some have or where can i buy and shifter for my 510. the hurst one is broken and i can not move the car. thanks steve Quote Link to comment
datzenmike Posted May 29, 2007 Report Share Posted May 29, 2007 Does it look like the infamous monkey motion shifter?http://i138.photobucket.com/albums/q251/datzenmike/CopyofA1.jpg Maybe a temporary piece of threaded stock with washers and a nut on the bottom, just to get you moving Quote Link to comment
kiznook Posted May 29, 2007 Report Share Posted May 29, 2007 what is that tranny? saw one REAL similar in a 521 in a junkyard, had a pan on the bottom like an auto. if it's a regular L tranny, they're easy to come by and easy to shorten too! Quote Link to comment
bucketoval Posted May 30, 2007 Author Report Share Posted May 30, 2007 it is the stock trans. it looks like i am missing the part that hold the shifter.you have the upper rod and the lower rod from the trans . i need the part that goes to the upper rod and hold the shifter. if that make sense. Quote Link to comment
