620 Factory Colors: Hood trim, Lift Crank, Tire Lift, Frame, ...
Cardinal Grammeter
Would like to use accurate factory colors for the following:
  • Hood trim (dark gray like grille?)
  • Fuel filter bracket on inner fender
  • Windshield washer bracket on core support
  • Windshield washer nozzles (cadmium plated?)
  • Ignition timing scale at crank pulley
  • Engine compartment light (this is steel and can rust, how was this finished from factory?  cadmium plated?)
Are the following semi-gloss black:
  • Hood Prop Rod
  • Tire lift mechanism
  • Lift Rod and Crank (or Red?)
  • Jack
  • Frame
I'm assuming any body metal on the underside is body color.
Wheels (all dark gray?  semi-gloss?)
I'm not going to get crazy about exact matches but would like to be in the ball park.  Who knows might consider getting Eastwood Cadmium Plating paint but it is a multi-layer process so probably won't do it.
Oh, PPG aerosol color blender works on Rustoleum and Krylon!
If anyone can add to this list, please do so!  Thanks!  (I may add to this list if I think of items I've forgotten.
  • Replies 3
  • Hood trim (dark gray like grille?)  Yes
  • Fuel filter bracket on inner fender  Body color
  • Windshield washer bracket on core support  Unpainted (or cad plated)
  • Windshield washer nozzles (cadmium plated?) Unpainted (or cad plated)
  • Ignition timing scale at crank pulley  Unpainted
  • Engine compartment light (this is steel and can rust, how was this finished from factory?  cadmium plated?)  Unpainted, or a light cad plating
  • Hood Prop Rod  No, unpainted
  • Tire lift mechanism  You mean the part under the truck?  Unpainted
  • Lift Rod and Crank (or Red?)  Red
  • Jack  Red
  • Frame  Black
I'm assuming any body metal on the underside is body color.  Yes, though the underside of the bed was commonly just primer, sometimes it got body color.  Or dealer undercoating..
Wheels (all dark gray?  semi-gloss?)  More like medium-light grey.  Darker than haze gray.
Anything "unpainted" would probably have been plated, but it wore off easily.
Most undercarriage stuff was black- suspension, torsion bars (with part numbers painted on), driveline, leaf springs, axle tubes, brake drums and backing plates, etc.
I'm thinking the typical plating used is the silver-ish zinc and not the golden cadmium plating?
Guessing silver-ish cadmium zinc plating.  Found impressive page comparing all the spray silver paints for resto and DAP 873 12oz Alum Spray Paint (UPC 0070798522596) was the closest to mimic this plating.  Need to find where to buy.  Eastwood stuff is crazy expensive.
Here is like to the article comparing 16 silvers.
Since this is very useful general information maybe I'll create a thread in a general forum for everyone to see.  We all have to deal with rusted plated parts.
UPDATE:  Can't find this DAP 873.  The comparison article was referenced in a 2010 article so it was performed before then.  It is possible it is NLA.
Still looking...
I think I've found it - or at least a cross-reference:
It  appears AP "bought out DAP paint" and their
AP Products 003-55273 Dap Touch N Tone Spray Paint Aluminum 10 oz
is the same as the original 873.
I compared a list of DAP UPC's and it appears the last 2 digits coincide with both the original DAP #'s and the new AP #'s.  Here is the list of UPC's
0070798523296     DAP INC. 866 12oz GL BEIGE SPRAY PAINT
0070798523197     DAP INC. 865 12oz GLD BROWN SPRAY PAINT
0070798523098     DAP INC. 875 12OZ BLK FLAT PAINT SPRAY
0070798522596     DAP INC. 873 12oz ALUM SPRAY PAINT
0070798522497     DAP INC. 876 12OZ BLK GLSS PAINT SPRAY
0070798522398     DAP INC. 874 12OZ WHT GLS PAINT SPRAY
0070798521292     DAP INC. 884 12OZ GL ALMOND SPRAY PAINT
0070798521193     DAP INC. 861 12OZ GL IVORY SPRAY PAINT
0070798520899     DAP INC. 869 12OZ ORNGE GLS SPRY PNT
0070798520691     DAP INC. 862 12oz GL YELLOW SPRAY PAINT
0070798520592     DAP INC. 867 12OZ GLS BLUE SPRAY PAINT
0070798520493     DAP INC. 882 12oz GLOSS GRAY SP PAINT
0070798520295     DAP INC. 870 12OZ BRIGHT RED PAINT SPRAY
0070798520196     DAP INC. 863 12oz GREEN SPRAY PAINT
0070798519893     DAP INC. 880 12OZ WHT FLAT PAINT SPRAY
0070798519794     DAP INC. 883 12OZ RED PRIME SPRAY PAINT
0070798517998     DAP INC. 759 SP GRAY METAL PRIMER
0070798517691     DAP INC. 756 12oz WH SEMIGLOSS SP PAINT
0070798517493     DAP INC. 754 12oz GRAY SEMI GLOSS SPRAY
0070798517394     DAP INC. 753 12oz BLACK SEMIGLOSS SPRAY
0070798517295     DAP INC. 752 12oz DK GREEN SG SPRAY PNT
0070798511361     DAP INC. 136 SP 12oz ALMOND PAINT
0070798511354     DAP INC. 135 SP 12oz ANT WHITE PAINT
0070798511309     DAP INC. 130 SP 12oz SANDSTONE PAINT
0070798511279     DAP INC. 127 SP 12oz FLAT GRAY PRIMER
Did Datsun use the Silver or Gold Cadmium plating?
Trying to choose a paint to simulate the proper plating.
Don't want to blow big $$$ on Eastwood stuff.
________________________
EDIT:  Rats - its the Gold
Might be able to blend it all with Silver, Gold, and Candy Apple Red and Green.
The Datsun Gold Cadmium appears to be very light and not as deep as the Eastwood stuff is.
So maybe Silver base, mist coat of Gold, and then Red and Green highlights from different directions.
Wonder if they make Candy Apple Gold
