Toney Posted January 4, 2015 Report Share Posted January 4, 2015 Sorry for making a whole other topic But I found two of these guys in my Datsun milk crates and I am stumped. Where do these belong?? Thank You Again! Quote Link to comment
Icehouse Posted January 4, 2015 Report Share Posted January 4, 2015 They go under the sway bar mounts and hold the splash pan on. Throw them away. That stupid pan just makes it harder to tighten the alternator. Quote Link to comment
Toney Posted January 4, 2015 Author Report Share Posted January 4, 2015 ok awesome just making sure theyre nothing important .Tahnk you! Quote Link to comment
datzenmike Posted January 4, 2015 Report Share Posted January 4, 2015 They go under the sway bar mounts and hold the splash pan on. Throw them away. That stupid pan just makes it harder to tighten the alternator. True that, but it does help draw air through the rad and keep water splash of the engine. 3 Quote Link to comment
Just Joel Posted January 4, 2015 Report Share Posted January 4, 2015 And it works well... I ran without for a while, bay stays much cleaner after install. 2 Quote Link to comment
Nuclear Water Boy Posted January 5, 2015 Report Share Posted January 5, 2015 True true true!!! If you have a splash pan, install it. Along with running cooler and keeping things a bit cleaner it also help with under car aerodynamics///pressure some. It's only four bolts to remove to adjust alt belt or replacement. Quote Link to comment
BrianE Posted September 15, 2015 Report Share Posted September 15, 2015 A quick follow up question re the "bits" ref'd by the OP and their placement under the sway bar mounts. In my case, I will be adding this splash panel and the "bits" to my 72 510. I have the "bits" and the panel courtesy of Futofab. Question is regards to the sway bar mounts. Never having removed a front sway bar before, is it safe to remove those mounting bolts and brackets with the car up on stands or is best practice to remove them with the car squarely planted on the ground???? Thanks! Quote Link to comment
datzenmike Posted September 16, 2015 Report Share Posted September 16, 2015 It shouldn't matter as long as the tires are evenly off the ground. Avoid one higher than the other. loosen off the ends first to relax them then you should be able to just unbolt them. BTW Brian welcome to Ratsun. Please start an introduction post in General Discussion and include something about yourself and your 510. Include all the pictures you like Quote Link to comment
