Charlie69's 86 720 King Cab DD
Charlie69
  • Replies 314
Wayno some of the shops are using 3M double sided tape to mount the sun visors on late model trucks that the metal is too thin to hold screws.  I have pulled some of the visors in junk yards in the past and they were just sheet metal screwed in.
  • Like 3
Well last week I went out to my dd and charged the battery, been sitting since before I had knee surgery.  It fired rite up.  Put it in gear stepped on the brake, my drive way has a good slope to it, the brake pedal hit the floor.  Got out and checked the fluid and master was empty.  Had this problem before and it was a slow leak past the rear seal that leaked brake fluid into the front of the booster.  In the past all I had to do was fill the master cylinder and pump the brake pedal a few times and recheck fluid level and drive, no prooblem.  This time however I filled the master got in and pumped the brakes and the pedal did not come up,  the rear seal was gone.  Had Tom take me to the VW junk yard where I have my 67 520 and my 85 720 ST are stored and pulled the new master cylinder off the 85.
Brought it home, put in, and topped off the fluid then I had brakes.  I need to have the lines flushed but I need to do the rear brakes first.  I will not drive it until i get the rear brakes done and get the system fushed.
I can drive a clutched vehicle again.  I could have driven sooner but did not want to until my surgeon gave me the OK.
  • 1 month later...
Thursday I installed the power steering gear box from my 85 king cab ST as this trucks box blew the pitman arm shaft seal.
My brother Garret and I Installed lower control arm bushings and new strut rod bushings yesterday on my 86 king cab.  Today we will install new tie rods, center link, sway bar bushings, and idler arm.
On Monday I will have new bushings pressed into a spare set of upper control arms and install them on my truck. then I will have the alignment done.
My brother and I finished the front end.  All I need to do is have the upper control arm bushings pressed in tomorow  and install the upper control arms.  Take the truck to Jack"s Alignment for front end alignment and the front end will be done!
When I had my left knee done back in 2010, my PT was PISSED when I showed up in my Beetle to one of my therapy sessions. Haha. Luckily beetle clutch pedals are softer than baby shit, so it didn't cause an issue.
  • 3 weeks later...
Going to be getting an automtic for this truck soon, so no more pulling stumps and tearing up bumpers.  At the time I will swap harness to the automatic I will adapt the power door wiring to the automatic harness so I will have another color dors on this either orange or blue or maybe 1 of each.  I will use the best doors I have no matter what color.  I am going to enjoy having an automatic.  Much easier to drive disabled!  LOL
  • 1 month later...
Thank you Captain 720.
I also pickuped up a front carpet from the junk yard that is in surprisingly good shape.  This will be installed after I buy some sound deadning and heat barrier mat and cartpet pad.
I scrapped off all the ol pad that was glued to back of the carpet.  I will scrape all the old pad off the floor of the truck when I pull the old carpet. Pictures soon.
Charlie
I just read the last few post.Lol Im that guy who ruins his doors--But I just dont throw junk in them ..Because im really big into car audio ive learn some things about deadner.Pretty much all your doing is adding weight.The stuff at home depot isnt going to work long term--stay away from tar based products.Dynomat is a great deadner but a person is mostly paying for the name.Buy thicker sheets--not in rolls. Its like painting with cheap house paint= more coats=more paint/money.Alot more work and no savings.
Sorry if you already knew all this.It might help some one who first timer.
Yocom
P.S The engine area im not so sure about.
The roll on roofing ads mass and damping. On top of this it's available, easy to work with and free. I did the entire interior and weight isn't a factor. Dynomat is likely the same thing but foil covered.
Charlie
The heat barrier is something i have never needed so im new to that also---I will look into it.Mabye I can add some help.
For normal deadener I live in Cali your in Az and it gets hot is reason for non tar/asphalt based stuff.Its been tested and tried dont seem work out in hot climates.
 Your looking for butyl Something in 80 mil should be ok for you.And im going to back out on saying dont buy rolled up deadener--Id just like sheet lol.Also dont forget you will need a roller.
Look at the rolls of GT mat--they ship fast and priced right.
Yocom
https://www.ebay.com/sch/i.html?_from=R40&_trksid=m570.l1313&_nkw=sound+deadener+80+mil&_sacat=0&LH_TitleDesc=0&_osacat=0&_odkw=sound+deadener+80+mil&LH_TitleDesc=0
Edited by SUPER_YOCOM
proof reading
Door? Larger enclosure, better location and out of the way, protected. I don't use doors, or haven't yet because they ruin the looks of the car they are in. If I did, I would flush mount and cover with a grill cloth panel, something black or matching the door card rather than an ugly and obvious speaker grill.
Let me start of with if we where to all the same it would be a very boring place.
Mike is right about doors larger and protected.Things can get very ugly looking if done wrong.
Because of my car audio wants and being in a 720--thin door. I have to use door pods to fit the depth of the 6.5 midbass speaker.I have this set in my truck.My highs speakers.http://precisionpower.com/product/p-65c3/
I plan on later moving the two smaller speakers in custom kicks and make new smaller pods for the midbass for the doors.New upholstery
Yocom
