The Soaring 521
a6m-zero
  • Replies 156
  • 1 month later...
  • 8 months later...
Ok , time to shake the dust off this build and get it ready for summer fun .
So we started out doing a shorter steering column , rebuild king pins , disc brakes all around .
 The build has changed a little ,  I am going to coil overs on the front , 720 4x4 springs in the rear ,  swapping out the L16 for a KA24d turbo with a five speed .
Still have to c notch the rear of the frame , repaint the frame and then start installing coils and drive train , and the swap the body over .
IMAG5985_1_zpsg6ax585u.jpgIMAG5984_zpsxqc2tmhr.jpgIMAG5983_zps6w48tn6i.jpgIMAG5986_zpsrdwivuzs.jpgIMAG5987_zpspntqjcg0.jpgIMAG5988_zpsrquvxwlx.jpgIMAG5989_zpsypnwwg6e.jpgIMAG5990_zpsxwbpjxyt.jpg20160403_173628_HDR_2_zpsi34gimv4.jpg20160403_173620_HDR_2_zpsluzbhmii.jpg20160403_173606_HDR_2_zpsjfrrurj2.jpgIMAG5963_zpsfvyunvkr.jpgIMAG5962_zpsdjgqwxyy.jpgIMAG5961_zpsvhfhdrvs.jpgScreenshot_2016-02-14-09-50-41_1_zpsxsoqIMAG5991_zpsem4dv2d5.jpg
Sounds like a busy summer..
Lol . . Both of these will be done before the end of May . The 510 is going to be the easy one . And the 521 is being built frame off so everything is easy to get to . And then we will set the body over to the new set up.
These swaps don't see long when you have everything pre prepped .
