Lozer Posted December 19, 2014 Report Share Posted December 19, 2014 so its rear sump. weighs 290lbs wet and dressed (internet says so) 24.13" height from bottom of oil pan to top of oil cap. exhaust is on the correct side and butt loads of support and there showing alot for cheap with trans and ecu. Discuss. Quote Link to comment
Cpl620 Posted December 19, 2014 Report Share Posted December 19, 2014 but why...?weight? get a rotary?wait for nissants 3 cylinder that weighs 88lbs and puts out 400hp?what about the honda S2K engine? that thing is pretty light too right? despite my hate for most things honda, that engine is great. Quote Link to comment
Duke Posted December 19, 2014 Report Share Posted December 19, 2014 It's been contemplated before. I believe Bob (the guy who built the 520 on a Miata chassis) started the swap, but didn't finish it. I like the idea, but many of the normally aspirated Miata's that I race against seem a bit gutless. With a blower though, I bet it would make a 510 scoot pretty well. Quote Link to comment
flatcat19 Posted December 19, 2014 Report Share Posted December 19, 2014 Honda spins backwards. Nissan's 3 cylinder will NEVER see a showroom. If you have the Miata motor, do it. How long is the tranny? Is your 510 a DD? Cuz it will be down a long time if you go forward. Quote Link to comment
DISLEXICDIME Posted December 19, 2014 Report Share Posted December 19, 2014 you will have to build a bigger tranny tunnel . the power to hassle ratio just isn't worth it if you ask me Quote Link to comment
flatcat19 Posted December 19, 2014 Report Share Posted December 19, 2014 the power to hassle ratio just isn't worth it if you ask me :rofl: Quote Link to comment
datzenmike Posted December 19, 2014 Report Share Posted December 19, 2014 130-ish HP in a similar weight 510? You could build a 2.3 for less and have more low speed torque fun. 1 Quote Link to comment
INDY510 Posted December 19, 2014 Report Share Posted December 19, 2014 They also don't really have a transmission mount. It has a PPF brace, bolted to one side of the transmission, which bolts to one side of the differential Quote Link to comment
Dime Dave Posted December 19, 2014 Report Share Posted December 19, 2014 The biggest plus for the Miata engine swap is the gear ratios in the transmission. If you have never driven one, that stubby little short throw stick with the ratios right on top of each other will suck you right in. Look at the rpm drops when shifted at 7000 rpm. 1st - (3.14) to 2nd (1.89) - 2787rpm (7000 to 4213) 2nd to 3rd (1.33) - 2074rpm (7000 to 4926) 3rd to 4th (1.00) - 1737 rpm (7000 to 5263) 4th to 5th (0.81) - 1330 rpm (7000 to 5670) Here is a link to a calculator that will work these numbers up for any transmission/final drive/tire-wheel size. http://www.gearboxman.co.uk/download/gearspeeds.v2.o95.xls Quote Link to comment
datzenmike Posted December 19, 2014 Report Share Posted December 19, 2014 The biggest plus for the Miata engine swap is the gear ratios in the transmission. If you have never driven one, the stubby, short throw stick with ratios right on top of each other will suck you right in. Look at the rpm drops when shifted at 7000 rpm. 1st - (3.14) to 2nd (1.89) - 2787rpm (7000 to 4213) 2nd to 3rd (1.33) - 2074rpm (7000 to 4926) 3rd to 4th (1.00) - 1737 rpm (7000 to 5263) 4th to 5th (0.81) - 1330 rpm (7000 to 5670) Here is a link to a calculator that will work these numbers up for any transmission/final drive/tire-wheel size. http://www.gearboxman.co.uk/download/gearspeeds.v2.o95.xls 1st - (3.14) to 2nd (1.89) - 2787rpm (7000 to 4213)....... 39.5% 2nd to 3rd (1.33) - 2074rpm (7000 to 4926)................... 29.5% 3rd to 4th (1.00) - 1737 rpm (7000 to 5263).................... 25% 4th to 5th (0.81) - 1330 rpm (7000 to 5670).................... 19% Quote Link to comment
Stoffregen Motorsports Posted December 19, 2014 Report Share Posted December 19, 2014 I've always liked that engine. They look just like a Lotus or Alfa Romeo twin cam. Nice vintage appeal. Quote Link to comment
DISLEXICDIME Posted December 20, 2014 Report Share Posted December 20, 2014 My miata feels like my built l18 as far as power go's Quote Link to comment
Lozer Posted December 22, 2014 Author Report Share Posted December 22, 2014 yea found a full engine set for as much as a ka-e and thought i would ask around as i couldn't find anything other then the 620 swap. Just an idle thought. Quote Link to comment
terolla Posted January 10, 2015 Report Share Posted January 10, 2015 http://community.ratsun.net/topic/52955-florida-dime/ Quote Link to comment
tr8er Posted January 10, 2015 Report Share Posted January 10, 2015 ^ nice example! Raised tranny tunnel, custom crossmember, some heady electrical work, but doable. As long as this is not a DD Quote Link to comment
