Draker Posted April 24, 2015 Report Share Posted April 24, 2015 How about BMW flag mirrors? I'm not a fan of fender mirrors.. but your car. If I had to choose, I'd go chrome. 2 Quote Link to comment
xUltra510 Posted April 24, 2015 Author Report Share Posted April 24, 2015 How about BMW flag mirrors? I'm not a fan of fender mirrors.. but your car. If I had to choose, I'd go chrome. I'd prefer fender mirrors. B) 1 Quote Link to comment
hobospyder Posted April 24, 2015 Report Share Posted April 24, 2015 i'd go chrome just to match the bumper and keep the car bright. that blue should not be darkened by black plastic 3 Quote Link to comment
xUltra510 Posted April 28, 2015 Author Report Share Posted April 28, 2015 Something really bad happened today on the freeway when my dad was driving the 510. We were going about 65 mph when all of a sudden I hear a sizzle/whistle sound. Then come the loud popping noises, after that the car just turned off and we had to move to the side of the freeway. I didn't smell anything. Before we left, we also tried to turn on the car in the garage when the loud popping began. It just pops, then looses power then turns off. Anyone know what the problem is? I was really upset. Quote Link to comment
EastBay521 Posted April 28, 2015 Report Share Posted April 28, 2015 check wires.ive had the power to the matchbox come off and it popped hella loud and died. its an L they aren't that hard to figure out Quote Link to comment
xUltra510 Posted April 28, 2015 Author Report Share Posted April 28, 2015 check wires.ive had the power to the matchbox come off and it popped hella loud and died. its an L they aren't that hard to figure out Yeah, it was pretty loud. My dad got someone checking it out, and other things. Quote Link to comment
xUltra510 Posted May 15, 2015 Author Report Share Posted May 15, 2015 I have a radio that I installed but I ran into a problem. I can't find the power cable! I want to be able to listen to cool tunes... How would I power the AM radio? How would I use modern speakers with the radio? Quote Link to comment
TENDRIL Posted May 15, 2015 Report Share Posted May 15, 2015 Solid blue should be radio power Quote Link to comment
xUltra510 Posted May 15, 2015 Author Report Share Posted May 15, 2015 Solid blue should be radio power I found one but it was connected to another solid blue. Basically two solid blues connected together from the harness. Quote Link to comment
skyblue Posted September 5, 2015 Report Share Posted September 5, 2015 hey man i found your thread. it was cool meeting you guys today.I didnt realize how much work has gone into your 510. great job. Quote Link to comment
Busta Nut Posted September 18, 2015 Report Share Posted September 18, 2015 I got the privilege to work on this last night...... Ran a little rough so first things first...... 4 Quote Link to comment
Busta Nut Posted September 18, 2015 Report Share Posted September 18, 2015 All of the intake valves were tighter than a virgin.......... Ehaust valves were loose whores..... ......this is on a hot engine...... 4 Quote Link to comment
Busta Nut Posted September 18, 2015 Report Share Posted September 18, 2015 .....while it's here.....we're gonna take care of this oil leak too..... ....one too many gaskets here..... ......and someone reeeeeally liked orange silicone..... 1 Quote Link to comment
Busta Nut Posted September 18, 2015 Report Share Posted September 18, 2015 Noticed the studs were in backwards......probably not allowing the nut to bottom out.... .....hence causing the leak..... Cleaned up the surface and reinstalled them...... 2 Quote Link to comment
Busta Nut Posted September 18, 2015 Report Share Posted September 18, 2015 Cleaned up the gasket surface..... 2 Quote Link to comment
Busta Nut Posted September 18, 2015 Report Share Posted September 18, 2015 One is a bit too long......bottoms out before it's tight..... Found one.... 2 Quote Link to comment
Busta Nut Posted September 18, 2015 Report Share Posted September 18, 2015 This was pinched more than I like...... ....all better..... Quote Link to comment
Busta Nut Posted September 18, 2015 Report Share Posted September 18, 2015 All back together...... 2 Quote Link to comment
Draker Posted September 18, 2015 Report Share Posted September 18, 2015 Is that valve cover gasket all rubber? Quote Link to comment
Lockleaf Posted September 18, 2015 Report Share Posted September 18, 2015 Hey busta, what's the reason for that plastic spacer on the fuel pump? My L18 doesn't have one, but my buddies L26 in his Z car did. When do they matter and when not? Quote Link to comment
Busta Nut Posted September 18, 2015 Report Share Posted September 18, 2015 Is that valve cover gasket all rubber? No.....that would be bad ass though...... ............metal impregnated paper material...... Hey busta, what's the reason for that plastic spacer on the fuel pump? My L18 doesn't have one, but my buddies L26 in his Z car did. When do they matter and when not? I can't say I've seen it without one ever....... ........think it's suppose to be there for proper spacing to the eccentric on the cam..... Maybe your fuel pump has a different bend in the arm..... Quote Link to comment
