qwik510 Posted December 17, 2014 Report Share Posted December 17, 2014 My memory is faulty. This is in my storage. I think it is a Roadster 5 speed box on an early 240Z bell housing. I can't find any numbers or markings on it. Thanks in Advance KR David Quote Link to comment
Doctor510 Posted December 17, 2014 Report Share Posted December 17, 2014 I'd ID it as a 240Z 4 speed IMO. Quote Link to comment
john510 Posted December 17, 2014 Report Share Posted December 17, 2014 Its not a Roadster 5 speed,the Roadster 5 speed has the monkey motion shift linkage. Quote Link to comment
qwik510 Posted December 18, 2014 Author Report Share Posted December 18, 2014 I guess I'll need to dig up a shifter and see how many gears it has. I don't recall having a 240z Trans around. I doubt I would have even saved a 4 speed back then. Quote Link to comment
DanielC Posted December 18, 2014 Report Share Posted December 18, 2014 Wait for DatzenMike to reply. He will probably tell you the type of transmission, what it came out of, the gear ratios, and probably a lot of other information. Quote Link to comment
datzenmike Posted December 18, 2014 Report Share Posted December 18, 2014 Not a Roadster 5 or 4 speed although it IS a 4 speed. The first Z car four speed was an F4W71A with the monkey motion shifter Used through '71. The F4W71B was first used on North American 240z cars starting Sept. '71 and up through the first year 280zx in '79. It's a wide ratio F4W71B used before the mid '74 model year. There was no North American 5 speed available until '77 as an option, but in Europe, the earlier Roadster 5 speed with a specially cast L series bell housing was available for the Z car. 1 Quote Link to comment
qwik510 Posted December 18, 2014 Author Report Share Posted December 18, 2014 Thanks Mike, I would have just PM'd you but I figured maybe someone else could benefit from this info. Anyone need a 240Z 4 speed Cheap? Quote Link to comment
Nuclear Water Boy Posted December 18, 2014 Report Share Posted December 18, 2014 Dave Just for shits and giggles, check to make 100% sure it is in fact a 4-puta,,speed DOH!!! Not questioning your knowledge Mike but I typically measure twice and cut once. Quote Link to comment
Dime Dave Posted December 18, 2014 Report Share Posted December 18, 2014 David, get a shifter and check the number of gears. I've never seen one, but rumor has it there were 5 speed, B shifter models with the top mounted "inspection plate". I would have to agree with Doctor510 & Mike that its likely a 4 speed from a Z car or maybe 620 truck. I have one stashed in my barn that looks just like it. Mine likely came from a truck as the only 240Z's I took apart had A type shifters. Quote Link to comment
qwik510 Posted December 18, 2014 Author Report Share Posted December 18, 2014 Never Doubt the King Rat. Mike knows his Datsun Transmissions. I just checked it and it is indeed a 4 speed. If anyone needs one, let me know. Quote Link to comment
datzenmike Posted December 19, 2014 Report Share Posted December 19, 2014 Have never heard of the transmission with the 6 bolt cover plate having been made into a 5 speed. For one there is no room in that transmission for the extra 5th gear and synchronizer hub and ring. If you look at the 5 speed below you can see that it is much wider further back towards the transmission mount than the 4 speed above it. What are those round things on either side of the 4speed just behind the adapter plate? and one round one on top just forward of the 6 bolt cover plate? They are not on the 5 speed. Well that's where the column shift rods would go if this was a R4W71B. It came in RHD and LHD. Quote Link to comment
