datsunfreak Posted December 7, 2014 Report Share Posted December 7, 2014 Do you have a link to the lowering blocks you used? http://www.amazon.com/McGaughys-Lowering-Block-Truck-33123/dp/B00B0Z2R5U/ref=sr_1_13?ie=UTF8&qid=1417988806&sr=8-13&keywords=2%22+lowering+blocks They are pretty generic though. Sometimes the U-bolts are too large a diameter though. Search for ones with the smallest diameter you can find. If you live near a Pep Boys, they keep these on the shelf. Quote Link to comment
datsunfreak Posted December 7, 2014 Report Share Posted December 7, 2014 I never believe reviews by someone selling something. After all, are they going to post "they work like shit... want my money back"? I suppose they will work but not sure how well. Well, I've used them on at least 5 cars with positive reviews each time. And I am selling nothing. B) I can say for sure they are, and look like a short cut. And I agree. But not all shortcuts are bad. ^_^ Quote Link to comment
ishnish Posted December 9, 2014 Author Report Share Posted December 9, 2014 Well thanks for the input guys. Regardless of the differing opinions on some subjects, what I did want to ask dasunfreak was that when you lowered your b210, did you have any vibrating of your car due to the angle of the driveshaft u-joints? Are yours angled 180° from each other? Also, regarding shocks, flatcat, would the gas-a-justs be the best option? I'm also a member of another forum regarding a whole different platform and on there the koni shocks are supposed to be amazing and KYB's are terrible (oe replacements if not worse). Not sure if the same applies here. Quote Link to comment
RatsunGT Posted December 9, 2014 Report Share Posted December 9, 2014 I have 2" blocks and cut springs / perch in the front til i put the zx struts on. But my driveshaft has no complaints driving everywhere 1 Quote Link to comment
flatcat19 Posted December 9, 2014 Report Share Posted December 9, 2014 Konis are great shocks. But you'll be hard-pressed to find a pair for a Datsun. KYBs cheaper stuff, GR-2 and Excel, are cheap OE replacement. GasAJust are some of their better lines. I'm a huge fan of KYB AGX shocks and struts. Quote Link to comment
datsunfreak Posted December 10, 2014 Report Share Posted December 10, 2014 what I did want to ask dasunfreak was that when you lowered your b210, did you have any vibrating of your car due to the angle of the driveshaft u-joints? Not even a little bit. A total drop of 1.5-2" isn't going to cause angularity issues like a 3-4" drop will. Now, if you u-joints are already on their last legs... ^_^ Konis are great shocks. But you'll be hard-pressed to find a pair for a Datsun. If his car is the 2dr with a trunk, not a hatchback, Konis for an 82-92 Camaro are a bit easier to find. :thumbup: Quote Link to comment
ishnish Posted December 10, 2014 Author Report Share Posted December 10, 2014 Thank you ratsungt for that pic. And thank you flatcat for the info. Datsunfreak, that is good to know. My car is in fairly good condition I don't (shouldn't) have problems with the u joints. Also, I have the same exact style datsun as yours. It's a 2 door sedan I believe. But a simple google search gave me this: http://classicgarage.com/802139.html Would these shocks not work for my car? Quote Link to comment
Nuclear Water Boy Posted December 10, 2014 Report Share Posted December 10, 2014 Removing leafs, using lowering blocks, experimenting with different added/removed leafs,,, guys just get the leafs rearked then add some good shocks. Quote Link to comment
datzenmike Posted December 10, 2014 Report Share Posted December 10, 2014 Absolutely. This can be done with good results, but it does not increase the spring rate. Normal suspension travel is rather long and soft on a stock car so lowering it only, is like driving your car over manhole lids that look only 1/2" high but are really 2 to 2 1/2" (or more) higher. You really need to limit suspension travel on a lowered vehicle. It will handle better also. Quote Link to comment
datsunfreak Posted December 11, 2014 Report Share Posted December 11, 2014 Also, I have the same exact style datsun as yours. It's a 2 door sedan I believe. But a simple google search gave me this: It is in fact a 2dr sedan. But your profile says coupe. ;) http://classicgarage.com/802139.html Would these shocks not work for my car? Yes, they will. Quote Link to comment
datsunfreak Posted December 11, 2014 Report Share Posted December 11, 2014 Removing leafs, using lowering blocks, experimenting with different added/removed leafs,,, guys just get the leafs rearked then add some good shocks. Yeah, but this... Normal suspension travel is rather long and soft on a stock car so lowering it only, is like driving your car over manhole lids that look only 1/2" high but are really 2 to 2 1/2" (or more) higher. You really need to limit suspension travel on a lowered vehicle. It will handle better also. What Mike said. B210 rear springs (and fronts for that matter) are crazy soft. If you don't do something to stiffen them up, it will be a serious problem after you lower it. Especially if you plan to run a wider than stock tire. Quote Link to comment
